Author Topic: SteveL #8 SRX twin shock rear brake pedal return spring. SteveH for SRX website!  (Read 1917 times)
Aye Steve,
This spring is no longer listed by Yamaha and is likely not in production as of 2019. So, what might be a substitute?
Went to measure up rear brake return spring for your #8 SRX twin shock and then remembered that Sally twin shock doesn't have one fitted as she has a set of McCrane rear sets fitted. The one fitted to Gert the Mono has a different part number, and I have no idea what the difference in dimensions might be.
However, do not despair. Put the Yamaha Part Number:90506-20223 into eBay and all that are available are in the USA. The same spring is also fitted to 2004-2009 FZ6, 1979-1982 YZ250 and 1980-1981 YZ465 as the rear brake pedal return spring. Hey presto! Yambits in the UK have the rear brake spring for the 1980-1981 YZ465 for the princely sum of £3-50 + P&P.  ;D
Here is the link to the relevant Yambits parts list: Yambits_YZ465-brake-pedal-spring
Let me know what you think, please.
Bill
Hi Bill, yes, that looks like the jobbie alright ....
just been out and measure up #8, looks to be 65mm long (2.5"), i found a spring on fleabay, which 'might' fit the bill, but your option is a better bet, i shall get off and order it now, and keep you posted.
as car was in for mot, i had a nice (if a bit cold) round trip of 80 miles to work on #6... joy  ;D
keep taking the tablets Bill  ;D , cheers
Hey Bill, springs arrived today, the ones you found are ok, fractionally too long, but a bit of persuasion with pliers make it an excellent return spring.
the springs i found on ebay, although supposedly the correct length (65mm) , were way too long ... must be a problem in translation from mandarin ..
so #8 is nearing completion. awaiting correct fuel tap service kit from M&P... who have sent 2 incorrect kits so far ... finally spoke to a human, and problem is now resolved (well, not got me money back yet.... but i live in hope)
cheers
