Author Topic: On being paranoid - oil  (Read 2834 times)
« on: April 18, 2007, 05:31:50 PM »
If you were me and had just had the sump drain on your beloved bullet helicoiled and the chap (reliable fellow) said that he had used an oily tap to catch the swarf and then flushed the engine with the old oil which was a week old anyway and then replaced it with some semi-synth stuff, would you drop that oil when you got home and refill with even more fresh?
boze
Re: On being paranoid - oil
« Reply #1 on: April 18, 2007, 05:47:01 PM »
without a shadow of a doubt.
for all a few litres of oil costs, compared to the cost of having your bike in hospital....
Damo
« Reply #2 on: April 18, 2007, 06:22:44 PM »
Yep, and I'd pass it through a filter. If I found a single filing I'd flush it again, if I didn't I'd still chuck the oil, but I'd sleep a little easier :-)
« Reply #3 on: April 18, 2007, 07:22:48 PM »
Yes, and if I had the tiniest shadow of a doubt still remaining I'd change the oil *and* filter after the first hundred miles.
I wouldn't however use semi-synth for the first lot as it's not going to be in there long enough to make any difference!
(and because I'm normally skint as well as paranoid :D )
ken
« Reply #4 on: April 18, 2007, 07:40:15 PM »
If these have an oil filter fitted change it now.  A little alloy swarf will go through the oil pump but stop at the filter. If it dont have a filter change the oil a few times. It shouldent do a lot of harm to roller bearings but would damage shells
« Reply #5 on: April 18, 2007, 09:39:14 PM »
Yep !
Oil and Filter change !   Nice clean straight 50 !
Your Three mains are roller bearings,but your Big End is a Floating Bush.
« Reply #6 on: April 19, 2007, 01:20:58 PM »
OK! job done. That's the fourth change in a week and a half. I ended up using 15/40 diesel mineral as I will change it again before it is due. Funny thing was it never takes the full 2.25L closer to 1.5-1.7L but so long as the dipstick is happy I am happy.
thanks for all the advice and for re-inforcing my paranoid tendencies
« Reply #7 on: April 19, 2007, 01:23:03 PM »
Yep !
No one here abouts stocks mongrades 40 or 50 weight. Where do you get yours or is that a silly question and how much does it cost roughly? After all one doesn't want to end up paying through the nose now.
S
« Reply #8 on: April 19, 2007, 01:33:54 PM »
Voices off from the Steffan abode...
"Oi just because I am happy does not make me a dipstick...."
« Reply #9 on: April 19, 2007, 10:32:12 PM »
Yep !
S
Silkolene Chatsworth and Hardwick.Cant remember which is which,but one is 40 the other 50.
In 5 litre tins.
Of course I get mine from work.
Not sure of the price.
« Reply #10 on: April 23, 2007, 09:00:57 PM »
Don't know the price..??...you mean you nicked it??...!!  wots that rhyme...
Taffy was a welshman taffy was a thief.... lol
pip pip
« Reply #11 on: April 23, 2007, 09:32:40 PM »
pip pip
Now Now !  Steady On !
  Cant be a Taff,wasnt born any where near the River Taff. I was born at Panteg Hospital,Griffithstown.
Just up the road from the Steel Works.
Some of us dont take too kindly to that rhyme.
« Reply #12 on: April 23, 2007, 09:52:39 PM »
Despite being a 'Dumpling' by birth, I ain't getting involved!
Just to say Chatsworth is the 40 SAE and does fine in Duke singles, roller big ends. Hardcastle, is just that for the oil pump when cold, but required for tired Indian plain big ends to keep them 'quiet'!
However, I should like to point out, that I am not insinuating that the 'Stalwarts' big end requires 'Hardcastle' because its tired!
I think I need to STOP!
Bye bye, Bill
« Reply #13 on: April 23, 2007, 11:10:02 PM »
Bye bye, Bill
My Big End is of the Roller variety !
Apparently with a silver plated needle caged bearing.....!
And have fitted oil pumps that deliver over 50% more than the standard items.
So I think I can get well lubed when required.
« Reply #14 on: April 24, 2007, 08:12:10 AM »
 halfords do a 20/50 designed for old engines, i've used it in my bullet for 2 years.
can't remember the name but its in an old style tin oil can, and its green and gold (the can not the oil).
350bullet
