Author Topic: Whats this an impression off.  (Read 2945 times)
« on: September 27, 2010, 12:55:07 PM »
Pat/Me - Short discussion on whether bolt length is important
Pat - Looks its ..................................... Tink,Tink,Tink.........Tonk
Pat - Ahh
Me - Don't panic pass me the torch
Short pause .........................
Me - Ok, lets go and get a cup of tea.
Re: Whats this an impression off.
« Reply #1 on: September 27, 2010, 01:42:48 PM »
Where did the bolt actually land?  ???
1 BMW C400X
« Reply #2 on: September 27, 2010, 04:33:10 PM »
Bolt down the camchain tunnel? :-\
« Reply #3 on: September 27, 2010, 06:18:20 PM »
Hopefully it'll come out OK. I once had to remove and completely strip a CB200 engine to retrieve an errant dowel, it was found at the back of the gearbox.
« Reply #4 on: September 27, 2010, 08:26:29 PM »
It was a washer falling down the camchain tunnel, fortunately the camchain tunnel doesnt sit over the main crankcase so it fell down behind the flywheel. We eventually managed to fish it out, but only just, the clearance between the casing and electric start ring gear is fairly small so it was tricky.
We got it all back together only to find the electric start had given up the ghost, so its still sat in my garage.
« Reply #5 on: September 27, 2010, 09:22:09 PM »
Had a taxing moment once when Jethro dropped an allen key down my XBR's camchain tunnel. Thank the lord for magnets on sticks.
« Reply #6 on: September 28, 2010, 08:07:38 PM »
Now then, I'm not totally at fault here! Was a nasty moment though :-[
Yes, the return of the XT has been stalled by a failure in the starter motor department, though I must say, I would rather discover the fault now than on a wet weekend as I set off home from the dragon! Parts ordered but can you remember how to put the starter motor back together Steve? I must say, I wasn't paying much attention at the time.
« Reply #7 on: September 29, 2010, 06:30:28 AM »
No problems, the lump hammer is still out on the bench so it shouldn't be too problematic  ;D
Who moved the bolt ? ;D
« Reply #8 on: September 30, 2010, 12:20:05 AM »
Once dropped a socket into the car whilst working on it - was sure it had gone down the exhaust so bolted it all together and started her up graunch crunch and other noisy sounds as the socket and the alternator got it on together....
