Author Topic: Honda flywheel puller D  (Read 4319 times)
« on: June 20, 2009, 08:04:38 PM »
Hi does anyone have the Honda Flywheel Puller D or a pattern part I can borrow - part No 079330010000
Dave Silver does have them - on special order - but will take over a week to get in.
It is for a CG125 but I would guess it fits many of the smaller Hondas.  I may even have one myself - but if I do who knows where it is.  There is no room for a 3-leg puller, this thingy is about 22mm OD thread and a threaded 'bolt' through that.
Re: Honda flywheel puller D
« Reply #1 on: June 21, 2009, 08:35:12 AM »
Haven't sorry Rog, but when I needed the flywheel off Abigail I just popped the motor down to the local bike garage and slipped the guy a £5. Job done in under a minute.
guest146
« Reply #2 on: June 21, 2009, 07:53:45 PM »
If you have access to or know an HGV fitter, the HGV wheel studs that are on 90% of heavy trucks are the same thread. Just wind it in and tap the pulley and off it comes. Fits the Dommi I know that for sure.
« Reply #3 on: June 21, 2009, 08:20:56 PM »
Thanks to both of you
Will liberate a wheel bolt off the next HGV that parks on the zig-zags outside the school...  ;D
KirriePete
« Reply #4 on: June 21, 2009, 10:08:08 PM »
Is it the same one as the C50/70/90 ?  Lefthand thread on the outer IIRC.  If so, I've got one buried in the Shed that currently has no purpose in life and would probably welcome some action.
« Reply #5 on: June 22, 2009, 08:55:24 AM »
Not sure if it is the same one - but my guess would be yes.  Any chance of a borrow?
KirriePete
« Reply #6 on: June 22, 2009, 08:58:49 AM »
I'll have a rummage in the shed tonight, post up a piccy so you can check then PM me with delivery requirements.
« Reply #7 on: June 23, 2009, 05:59:54 PM »
You can quite often use the rear wheel spindle.
« Reply #8 on: June 23, 2009, 07:22:52 PM »
Most often to hold the rear wheel in...  ;D
I had thought that as I was pulling the cases off - but the rear spindle is 10mm or 12mm and the hole is 22mm or there abouts but a good thought.
blew
« Reply #9 on: June 23, 2009, 09:44:08 PM »
I have a puller that fits small Hondas-50/70/90 etc..Where are you?
crackedhead
« Reply #10 on: June 23, 2009, 09:57:09 PM »
lings.com show that item is available, at £6.24, for next day dispatch.
Good luck
« Reply #11 on: June 24, 2009, 08:27:19 AM »
Hi Blew
I am in Cwmafan / Port Talbot.  Thanks, however Kirriepete is sending me one that is clutter in his shed.
blew
« Reply #12 on: June 24, 2009, 09:16:56 AM »
I'm quite close.If you want it today,ring me on 07761330285
« Reply #13 on: June 25, 2009, 11:51:23 AM »
Hi Blew
Thanks - was wall to wall with kids last night - boss in meeting till 9:30ish so did not have a chance to call.  Pete's turned up this am in the post.
Where abouts are you?
