Author Topic: Interesting XBR on ebay  (Read 1160 times)
« on: May 12, 2009, 07:48:09 PM »
It's had a few mods, cooler, filter, alloy box section s/a low miles.  Could be a good little bike.
Here
« Last Edit: May 13, 2009, 07:28:11 AM by onepot »
Re: Interesting XBR on ebay
« Reply #1 on: May 13, 2009, 07:30:04 AM »
Blimey, that swing arm is short!
« Reply #2 on: May 13, 2009, 07:56:30 AM »
There was a guy at Dent the other year with exactly the same thing on his XBR.  Not sure who made them, probably an 80's accessory when they first came out as I can't ever remember seeing ally s/a's for XBR's advertised. It was a really nicely made piece of kit, looked really trick, but I can't see a lot of point other than looks as there's nothing wrong with the original XBR S/a as far as I know.  Maybe the shorten wheelbase would sharpen up the handling a bit?
« Reply #3 on: May 13, 2009, 08:16:38 AM »
The swing arm might be a quality bit of kit but it doesn't do much for the look of the bike, looks like its had a rear end shunt. Bugger the quicker steering he needs to get the standard arm back on.
« Reply #4 on: May 13, 2009, 04:32:53 PM »
Agreed, there's nothing wrong with the standard swinging arm. It's as stiff as it needs to be. I don't see the point of making one item way stiffer than the other components of the chassis. A super stiff arm won't cure any flex in the frame or forks.
And, by goodness, there's absolutely nothing wrong with the XBR's handling anyway.
