Author Topic: Indicator bulb compatibility  (Read 464 times)
« on: June 22, 2016, 10:33:00 PM »
Does anyone know whether the standard XBR 21W indicator bulb is interchangeable with an R10 bulb. I found that the distance from the pins to the contacts on both bases is 7.5mm, but are the bases the same diameter?
Re: Indicator bulb compatibility
« Reply #1 on: June 22, 2016, 10:43:30 PM »
Looked some more and found both are BA15S. Premature posting  :'(
« Reply #2 on: June 23, 2016, 08:47:36 AM »
......ah yes Matt, now you've turned 50 you may find premature elucidation becomes an increasing problem.....
.....................I often find I've fired off a posting onto the forum without being fully composed....
.......................................................Sorry? eh , what!..... ??? ;)
« Reply #3 on: June 23, 2016, 11:12:57 PM »
 ;D
« Reply #4 on: June 24, 2016, 01:09:23 PM »
Fair play
