Author Topic: fmx650 engine into rs frame  (Read 1394 times)
« on: March 23, 2016, 09:59:07 AM »
Ay up chaps.
I have swapped my Bro my xbr500 engine, which was half way into my rs, for his recently aquired fmx engine. Pete, hopefully you are cool with this. The fmx engine has a more modern appearance which didn't quite gel with the cafe racer look mick is after, plus there are technical questions arising, hence this post. Gordon (the rs) is already highly modded so a few more technical hurdles won't hurt!
My first question is regarding the oil pump circuit. I'm wanting to make a special oil tank to go under the seat but positionally more like a traditional brit bike. How will this affect the oil pump, given that the fmx has a higher oil tank?
Thanks in advance for any advice.
Re: fmx650 engine into rs frame
« Reply #1 on: March 23, 2016, 11:48:55 AM »
No sweat Michael, a 650 engine in the RS frame sounds like a recipe for fun to me! If you PM me your email address, I'll send you a PDF of the SLR650 manual I have. On pages 2.0 and 2.1 it has two good diagrams of the oil circuit. The take off out of the frame oil tank down to the oil pump is below seat height anyway IIRC.
HTH,
Pete.
« Reply #2 on: March 23, 2016, 12:13:56 PM »
HTH,
Pete.
YID. That's a great help Pete.  Many thanks. Pm on its way.
Andrew.
« Reply #3 on: March 23, 2016, 12:23:37 PM »
Manual sent!
Sorry about mixing names up in last post - I've reached an age where I have a job to remember who it is looking back at me from the mirror when I have a shave....  ???
« Reply #4 on: March 23, 2016, 12:33:57 PM »
Manual sent!
Ha. Know the feeling paul.
Thanks for that. I'll send you a photo, see what you think.
« Reply #5 on: March 23, 2016, 02:04:43 PM »
Manual sent!
My solution was to stop shaving. Mind you I did that when I was but a callow youth. Just think of the time I've saved in my lifetime.....
« Reply #6 on: March 23, 2016, 07:49:25 PM »
Bloody hell how long is ya beard Ian??....must make those ZZ top blokes look like part timers if you ain't shaved since ya youth (ah I'm totally assuming your NOT in your youth any longer).....
« Reply #7 on: March 24, 2016, 08:05:56 AM »
Hi Pete. Yes I had a look at the fmx engine slotted into the rs frame on Tuesday evening and I must admit it does look better than the XBR one that was in there originally, like Andy says it seems to lend itself to the more "modern" look of the fmx engine. Defo going to be an interesting project that's for sure, and yes I also think it shud be a recipe for fun....luckily I shud hopefully be able to swing a leg over it once it's complete and take it for a spin...cheers, Michael
« Reply #8 on: March 24, 2016, 10:16:11 AM »
Be nice to see some pics....
« Reply #9 on: March 24, 2016, 10:22:50 AM »
Er.... would if I could!  ???  ;D
« Reply #10 on: March 24, 2016, 01:26:18 PM »
Has anybody actually got photos onto here from i pad or kindle fire?
If so I'm all ears. (well tbh I have rather a long nose too)  ;D
« Reply #11 on: March 24, 2016, 07:27:40 PM »
Yes it would....of semi clad ladies draped over some bikes :) :) ;) ;)
« Reply #12 on: March 26, 2016, 09:31:37 AM »
Pete, thanks again for the pdf doc. I had a chance to peruse it this morning. As you say, the oil inlet hose takes off from the tank very low down anyway, so I should  find that a tank between where the xbr one sits and the seat should be about the same height.
Next question to all: what stops the system from wet sumping? There is a device labeled "check valve" but where it is situated it looks more like a relief valve to me.
« Reply #13 on: March 26, 2016, 09:52:06 AM »
[quote author=Propellor link=topic=8085.msg55406#msg55406
[/quote]
Eerrr...dunno, but where's the pics of scantily clad ladies draped over the bike?? ;) ;) ;)
« Reply #14 on: March 26, 2016, 10:27:00 AM »
Have you tried rocket garage sir? I think you'll find all you need there.  ;D ;D ;D :o ??? :P 8)
