Author Topic: Front Brake Light Switch For me XR600R  (Read 826 times)
PedroJuan
« on: February 16, 2007, 06:11:37 PM »
Hi,just wondering if anyone can give me some advice on my XR600? Im taking it for a mot soon but have been told that i will need a front brake light switch,troble is that im not really turning up any places to buy one.so....can anyone give me a link to a uk based site that deals in these hydrolic banjo switches?My XR 6oo R is a D reg 87.Or maybe i could get one from a honda xl that would fit?Any help would be great.
Re: Front Brake Light Switch For me XR600R
« Reply #1 on: February 16, 2007, 06:43:08 PM »
M & P do them starting from £11.99 to £15.99 not including P & P.
Single or twin banjo switch ,metric or imperial ,stainless.
http://www.mandp.co.uk/  Or phone 08712 - 22 11 22
Hope this helps..
PedroJuan
« Reply #2 on: February 16, 2007, 06:54:31 PM »
hay! i had forgot about them.(M+P).ur the man! thanx very much:)
bullet350
« Reply #3 on: February 16, 2007, 07:06:18 PM »
my enfiled doesn't have a front brake light switch.
It didn't need one for the MOT two years ago, then last year it did need one, and now the tester says the law has changed so you only need one brake light switch.
Also it doesn't matter if its front or back.
Ring the test centre before to check. If they say it does then try ringing another. Is it me or do they seem to make it up as they go along?
350bullet
PedroJuan
« Reply #4 on: February 16, 2007, 07:11:01 PM »
Hi thanx for that,...Yeah called the mot shop b 4 i went down and they said your gonna need one if its reg after august 86.and it is so guess im putting one on then...doh.
« Reply #5 on: February 18, 2007, 02:21:23 PM »
Has often confused me - that in normal road riding most of the work is done by the front brake - to a point on some bikes that I have not used the back - but then on many budget 70's 80's and even modern ones (90's on) the only switch is on the back brake - guess this may be because - as far as I remember - the only brake yu HAVE to have fitted in the States is a rear.  Have been a fan of aftermarket, or bodged on from a breakers - front switches - afterall I do like the buerk behind me in the repmobilke to at least be given a clue about me stopping.
