how to paint brake caliper
Topic: how to paint brake caliper (Read 1575 times)
tony636
May 12, 2012, 02:45:42 PM »
Hi there all. I want to paint my brake caliper as i am board of the gold ones that are on the bike. What is the best stuff to use? I know I need HT Paint but i do not know what is best brand of paint for this can some one help point me in the right way
Re: how to paint brake caliper
May 12, 2012, 07:59:10 PM »
I've used Sperex VHT paints before with good results. I think you can still get stainless brake piston kits from Wemoto which stops the usual pitting.
May 12, 2012, 11:09:13 PM »
Painting isnt the problem...its just that brake fluid is a pretty good paint stripper!!
So you need to make sure that none gets onto your efforts
HTH
Dyslexics have more nuf
May 13, 2012, 07:44:56 PM »
Never bothered with high temp paint... calipers on srx's just don't get that hot... if they did your fluid would be boiling.
I use smooth hammerite spray... always worked ok for me... and it has a certain tolerance to hydraulic fluid.
May 13, 2012, 10:16:20 PM »
Thanks for that tip Steve...I will try it on the rebuilt Hybrid!
tony636
Reply #5 on:
May 17, 2012, 11:21:14 AM »
Thanx for all your comments i will let you know how i get on and post some pics for you guys.
tony636
Reply #6 on:
May 18, 2012, 04:56:27 AM »
Hi there Steve just a quick question do you use a primer?
Reply #7 on:
May 18, 2012, 07:04:57 AM »
You dont normally need a primer for Hammerite paints
tony636
Reply #8 on:
May 18, 2012, 07:49:15 AM »
Ok thank you Ian
Reply #9 on:
May 19, 2012, 07:31:00 PM »
Quote from: ian650 on May 18, 2012, 07:04:57 AM
Sorry Ian,
Best to use a primer if it is aluminium! You can get a reaction from the aluminium and the Hammerite, bubbles and then flakes off. Doesn't adhere as well as to clean iron oxide.
Reply #10 on:
May 23, 2012, 11:11:03 PM »
Clue was in the word "normally" Bill...my apologies
Last Edit: May 24, 2012, 09:56:15 PM by ian650
Reply #11 on:
May 24, 2012, 06:51:14 PM »
No apologies required Ian.
I'm just being a pedantic old >>>>>>>>>>>>>!
Bill.
Reply #12 on:
May 24, 2012, 09:18:46 PM »
I'd say use a good etching primer....unless hammerite do a primer.... not sure, don't think i have ever used primer.... it may depend on the actual alloy
Reply #13 on:
May 24, 2012, 09:58:23 PM »
There you are you pedantic old bu99er Bill
http://www.hammerite.co.uk/products/special_metals_primer.jsp
Reply #14 on:
May 24, 2012, 10:23:05 PM »
Thank you Ian.
I note, SteveL is also flashing his etchings!
Toodle pip, Bill.
