Author Topic: how to paint brake caliper  (Read 1562 times)
tony636
« on: May 12, 2012, 02:45:42 PM »
Hi there all. I want to paint my brake caliper as i am board of the gold ones that are on the bike. What is the best stuff to use? I know I need HT Paint but i do not know what is best brand of paint for this can some one help point me in the right way :D
Re: how to paint brake caliper
« Reply #1 on: May 12, 2012, 07:59:10 PM »
I've used Sperex VHT paints before with good results. I think you can still get stainless brake piston kits from Wemoto which stops the usual pitting.
« Reply #2 on: May 12, 2012, 11:09:13 PM »
Painting isnt the problem...its just that brake fluid is a pretty good paint stripper!!
So you need to make sure that none gets onto your efforts
HTH
« Reply #3 on: May 13, 2012, 07:44:56 PM »
Never bothered with high temp paint... calipers on srx's just don't get that hot... if they did your fluid would be boiling.
I use smooth hammerite spray... always worked ok for me... and it has a certain tolerance to hydraulic fluid.
« Reply #4 on: May 13, 2012, 10:16:20 PM »
Thanks for that tip Steve...I will try it on the rebuilt Hybrid!
tony636
« Reply #5 on: May 17, 2012, 11:21:14 AM »
Thanx for all your comments i will let you know how i get on and post some pics for you guys.
tony636
« Reply #6 on: May 18, 2012, 04:56:27 AM »
Hi there Steve just a quick question do you use a primer?
« Reply #7 on: May 18, 2012, 07:04:57 AM »
You dont normally need a primer for Hammerite paints
tony636
« Reply #8 on: May 18, 2012, 07:49:15 AM »
Ok thank you Ian :)
« Reply #9 on: May 19, 2012, 07:31:00 PM »
Sorry Ian,
Best to use a primer if it is aluminium! You can get a reaction from the aluminium and the Hammerite, bubbles and then flakes off. Doesn't adhere as well as to clean iron oxide.
« Reply #10 on: May 23, 2012, 11:11:03 PM »
Clue was in the word "normally" Bill...my apologies  ;D
« Last Edit: May 24, 2012, 09:56:15 PM by ian650 »
« Reply #11 on: May 24, 2012, 06:51:14 PM »
No apologies required Ian.
I'm just being a pedantic old >>>>>>>>>>>>>!  :-X
Bill.
« Reply #12 on: May 24, 2012, 09:18:46 PM »
I'd say use a good etching primer....unless hammerite do a primer.... not sure, don't think i have ever used primer.... it may depend on the actual alloy
« Reply #13 on: May 24, 2012, 09:58:23 PM »
There you are you pedantic old bu99er Bill  ;D
http://www.hammerite.co.uk/products/special_metals_primer.jsp
Ian :)
« Reply #14 on: May 24, 2012, 10:23:05 PM »
Thank you Ian.  ;D
I note, SteveL is also flashing his etchings!  :o
Toodle pip, Bill.
