Author Topic: This would have been a sore one! :¬(  (Read 2028 times)
« on: August 08, 2019, 08:10:46 AM »
eBay advert of an Inter for sale. No, I'm not taking on another 'project'!  ;)
1948-NORTON-INTERNATIONAL-500-PLUNGER
Keep safe, Bill
Re: This would have been a sore one! :¬(
« Reply #1 on: August 08, 2019, 09:00:13 AM »
yes, I've noticed that - fairly easy to put it into running order but the oil tank may be hard to fix. It'll be interesting to see what it fetches.....
« Reply #2 on: August 08, 2019, 10:14:19 AM »
It may be an optical illusion, but it looks to me like the frame is bent.  :o
« Reply #3 on: August 08, 2019, 01:17:53 PM »
They all look like that sir.....
If it is, easy enough to straighten with a scaffold pole.
« Reply #4 on: August 08, 2019, 05:46:19 PM »
I've done that a few times with bicycle frames, but then again I've never done 70mph on a bicycle. Not for the want of trying, I should add.  ;D
« Reply #5 on: August 09, 2019, 08:58:17 AM »
70? A decent Inter should do 90.....
Mind you, your attempts at doing 70 on a pushbike may have contributed to your recent health issues......
« Reply #6 on: August 09, 2019, 12:11:43 PM »
Quite possibly Ian, though there is no empirical link between cycling and prostate cancer AFAIK....
« Reply #7 on: August 10, 2019, 04:34:19 PM »
What about wearing lycra though Pete, I reckon that could do it.
« Reply #8 on: August 10, 2019, 05:45:51 PM »
You could be right Ian, though obviously I'm not a MAMIL anymore, I've now graduated to being an OMIL  :(
« Reply #9 on: August 11, 2019, 08:44:36 AM »
Final bid just short of £12K. Not bad for what would probably be a fairly straightforward rebuild.
« Reply #10 on: August 11, 2019, 09:32:55 AM »
MMMmmm! Hope the head and barrel castings are servicable after being hammered. Lots of careful checking, as even a few thou off centre to the crank could prove expensive.  :-\  I'm still no convinced that the scaffold pole job on the frame will be enough. How ductile are the lugs and steering head?   :-\
Could always be given a cosmetic job, with no guts and wheeled around for a Pebble Beach entry!  ;D ;D
Toodle pip, Bill
