Author Topic: Enfield Bullet Classic 500 LE not starting!  (Read 1167 times)
« on: June 23, 2019, 01:20:43 PM »
One of those obscure starting problems with a camoflage painted Enfield Bullet Classic 500 Limited Edition machine.
Link to image of machine type: Enfield_Bullet_Classic_500_Limited_Edition
Initially, ran but reluctantly responded to the throttle. Then would not start. Ignition turned on and a single pulse was measured from the fuel injection and a single pulse was measured from the ignition, Nothing else!  ???
Checked through the wiring and components, including replacing ECI unit, ignition pulse coil, no apparent fault!  ???
Finally, checked throttle position sensor and "HEY PRESTO"! Disconnected the sensor and the bike started and ran.
As for the fixing of the fault etc. not a clue  :-\  and thank goodness the bike isn't mine. If I find out more I will add it to this thread.
Continue to work on the Duke 450 electrics and fittings. Yes, I know I'm slow, but if I go too fast, it could all end in tears and the smell of burning plastic!  :-[
Re: Enfield Bullet Classic 500 LE not starting!
« Reply #1 on: June 24, 2019, 09:04:49 AM »
Ah, the toxic smell of an overused credit card! :'(
« Reply #2 on: June 24, 2019, 11:52:37 AM »
 ;D
