Author Topic: You know how it starts......  (Read 2249 times)
« on: March 20, 2018, 08:35:25 PM »
Yep it started when I bought the Enfield when the BMW's electrics died. I thought I'd just tidy up the BMW, then I found out the ignition switch electrical part had fallen apart (the switch is in two pieces, a key switch which turns the steering lock and the electrical bit and the electrical bit itself). No problem I thought I will get a used one from Motorworks, no chance they haven't had one in ages. So while I was pondering what to do next I took a good look at the rest of the harness, oh dear that will need replacing. Never mind Motorworks have got a used harness and I decided to splash out on a new ignition switch electrical bit. Bollocks now I've noticed the key bit of the switch is broken and guess what Motorworks haven't got a used one or even a new one. Come to that no-one in the world has one. OK put that aside for more thinking.
The BMW stood for four weeks whilst I was doing this and when I came to move it to begin the work it wouldn't move, the rear brake had seized on because the disc had rusted! Right replace disc and pads and check front disc. What! Covered in fork oil from the seal that has started leaking. Right new pads for that. Strip the forks for new seals. Bollocks one slider won't come off because the bolt in the bottom is just turning. Try usual remedies (put top cap back on, heat bolt, bit of broomstick etc) nothing works. Get out the Dremel to drill and grind off the bolt head. Hang on when did the flex on the Dremel get cut through!?
So what started out as a simple job has turned into an almost total strip down of the bike. It's always the same with old bikes isn't it, if they're running leave them cos if you once disturb one component everything else needs to find it's balance again.
Meanwhile the Enfield is doing good service and I've managed to hang on to it thanks to a good friend who came to my rescue, good job really as without it I would have been without a bike for weeks now.
Re: You know how it starts......
« Reply #1 on: March 21, 2018, 10:01:38 AM »
That all made me smile. But isn't that why we ride them? Always something to keep us out of mischief......
Glad you could hang on to the Enfield.
« Reply #2 on: March 21, 2018, 10:38:23 AM »
Yes, pleased to hear you managed to keep hold of the Enfield Ian.
One day I'll tell you how long it took for me to cure the leaking float valves on my F650 (nearly a week!), and how many times I had to remove and re-fit the carbs. .....
« Reply #3 on: March 21, 2018, 12:17:10 PM »
Great news that you can keep the Enfield Ian 😀
« Reply #4 on: March 22, 2018, 05:38:51 AM »
Thanks fellers I too am happy I can hang on to the Enfield as it is a lovely bike, a true thumper in my opinion 500cc, air-cooled and simple. I went to the coast on it yesterday and it just romps along the twisty roads in top happily.
Ian is of course right I love old bikes because they do need input in the form of tinkering which gives one a chance to really get to know them. I would imagine Pete that when you are a very old man in a rocking chair you will still be able to remember how to remove and re-fit F650 carbs! My wife always laughs when at an autojumble I point to something in a pile of rusty bits and say something like 'if I needed a front caliper for an R65 that one's got the right offset'. Me wear an anorak? Don't we all.
Anyway I've turned a corner with the BMW and am now re-building rather than tearing apart and just in time for warmer weather.
Have fun.
« Reply #5 on: March 22, 2018, 09:48:22 AM »
Turned a corner? How many times have I thought that only to realise I've just gone into a cul de sac.......
