Author Topic: Exhaust headers  (Read 2943 times)
guest1406
Exhaust headers
« on: May 15, 2015, 01:31:21 PM »
Hi all,
Im on to my exhaust now, headers are done, 2 into one joint is done and can is ready.
I'm in need of steel ring / disk that I can weld to the headers so that the collars, when bolt to the head will pull the whole header air tight. I tried to cut and shape one but it came out bodged, tired to do it a hole saw but they came out way off.
Any suggestions?
Outside diameter measuring 44mm - Inside diameter measuring 33mm
Cheers,
Mackenzie
Re: Exhaust headers
« Reply #1 on: May 15, 2015, 10:18:39 PM »
Aye Mackenzie,
Try this Ebay 'Lot Number': 360659012053
Probably best to contact first afore placing order. Seems cheap compared with time and effort phaffing. OK, OD maybe a bit big, but short of a BIG press, double edged die etc this is going to be the easiest.
Apologies if it raises false hopes.
Full_Ebay_link
Re: Exhaust headers
« Reply #2 on: May 17, 2015, 08:55:20 AM »
Out of interest how did you make your 2-1 connector ?. Do you have any pictures
guest1406
Re: Exhaust headers
« Reply #3 on: May 17, 2015, 10:42:11 AM »
I used this method this guy uses:
http://www.hdforums.com/forum/sportster-models/638096-my-70-2-into-1-exhaust.html
Mine came out like this. A lot smaller of course, i cleaned it up and it looks nicer now
Mackenzie
[deleted to save space]
Re: Exhaust headers
« Reply #4 on: May 18, 2015, 07:09:36 AM »
Looking good, bit of cleaning up and it,ll look the biz.
Re: Exhaust headers
« Reply #5 on: May 19, 2015, 08:12:40 AM »
I love this idea. I'm sure its not quite as straight forward as it looks, but is anything  :-\
guest1406
Re: Exhaust headers
« Reply #6 on: May 24, 2015, 09:22:28 PM »
Bill I just bought a few of those washers and the fit absolutely perfect!!! Once i get some more gas for the welder ill measure them up and do it. Cheers for that!!
Honest timbo if I can do it anyone can!
Mackenzie
Re: Exhaust headers
« Reply #7 on: May 24, 2015, 10:12:21 PM »
Aye Mackenzie,
That was just a 'light bulb' moment and a poke at Google, "just in case"!  ;)
Pleased to have been of assistance.
