Author Topic: Repairing pin holes in a tank  (Read 11976 times)
« on: February 06, 2015, 08:53:57 PM »
One of the XBR tanks I have just stripped has a few small holes. There is evidence of previous repair. I don't want to go down the tank sealer route. Anyone any ideas? Should I get it soldered, brazed?
Re: Repairing pin holes in a tank
« Reply #1 on: February 06, 2015, 09:26:49 PM »
Evening Tim , try looking up www.frost.co.uk they do a comprehensive body soldering kit, all you,ll need is a blow torch. Cheers Michael
« Reply #2 on: February 06, 2015, 10:38:26 PM »
Thanks Michael, I'll look into it. Just exploring my options at the mo.
« Reply #3 on: February 07, 2015, 09:48:01 AM »
I cant answer your question, but, given your previous exploits with chemicals, maybe you can answer mine. Is araldite resistant to petrol?
I'm hoping it is because I've just repaired a pinhole in my 250rs tank. Worrying thing is, it's right in the family jewels area!
Anyone tried this? Repairing tanks with araldite that is, not splashing petrol over ones gonads. (Although if you've tried that and it turns out to be nice, let me know)  ;D
Dick Scratcher
« Reply #4 on: February 07, 2015, 10:38:37 AM »
Used to be able to buy a 'dedicated' fuel tank repair compound, dunno if it's still available....Google it.
« Reply #5 on: February 07, 2015, 06:07:12 PM »
Cheers DS.
Oldtimer
« Reply #6 on: February 08, 2015, 07:26:02 PM »
Araldite IS resistant to petrol!
Mike
Honda XBR500
« Reply #7 on: February 09, 2015, 06:40:23 AM »
Epoxy is resistant to petrol, although I would prefer a higher-quality product like WEST System resin and glass fabric.
« Reply #8 on: February 09, 2015, 07:18:53 AM »
Thanks guys.
« Reply #9 on: February 09, 2015, 10:28:34 AM »
Yes, having done a bit of research on this subject, I'm going to go down the araldite route, so thanks for your help guys. Where the pinholes are located, I'm going to tap that area in with a hammer to create a small dent, so the araldite will fill the dent and can then be smoothed off with the surrounding area. I'm not going to paint beyond the primer stage, until I'm satisfied the repair is petrol tight.  :)
« Reply #10 on: February 09, 2015, 08:05:50 PM »
hi  I put chemical metal  in a couple of pin holes in a gsx tank
its had petrol in it now for about 3 weeks so far so good no leaks
« Reply #11 on: February 09, 2015, 09:27:44 PM »
Hi Tommy, was it JB Weld? That's another product I'd thought of. Let us all know how the gixer tank does in the long term  :)
« Reply #12 on: February 11, 2015, 12:24:13 AM »
Aye timbo,
Not the same I know, but after making some good chutney and leaving it to 'mature' in an aluminium jelly pan, said pan developed pin prick holes!  ??? Aceatic acid!  :o
Quote from the dreaded Wicki P "Vinegar is a liquid consisting mainly of acetic acid (CH3COOH) and water. The acetic acid is produced by the fermentation of ethanol by acetic acid bacteria."
So, as you can see the added ingredient of 'petrol' may turn to vinegar in your tank like an opened unfinished bottle of Beaujolly! I know, that's anathama to many on this site!  ;)
Anyway, as we were living 16miles from the nearest ironmongers and had a glut of apples to make into more chutney, the pan was filled with water and every water drop on the outside of the pan marked with a soft pencil. The pan was then dried off, given a wee dink with a ball pein hammer on the outside of each hole and then the holes were filled with 'JB weld'. The pan was then sat on the 'Carron' stove, like a 'Rayburn', and warmed for 24 hours. 32 years later we are still making jam, jelly, marmalade and chutney in it and the JB hasn't budged!  ;D
Just don't leave the contents in the tank to corrode it, drink it or ride it dry!  ::)
Good health to you all, Bill
« Reply #13 on: February 11, 2015, 12:37:28 AM »
hi tim yeah it was jb weld its a spare tank off my gsx 1100 so im using it as a bit of a trial and error type thing
if it holds up im planning to seal the tank with a product  I got  called kreem fuel thank liner kit im thinking if its sealed from the inside and outside should be leak proof
kreem say their product is ethanol safe
ps has any body used any of these vinyl  wrap products a carbon fiber xbr might be neat (maybe)  tommy
« Reply #14 on: February 13, 2015, 09:35:07 PM »
So far, I'm impressed with the araldite, or should I say the time and effort Alison has put into trying to save this tank  ;)
Hi Propellor, the last of my worries is petrol leaking round my crown jewels, my trousers have totally disintigrated around that area, and the only thing i can put it down to is my hydochloric acid tank washing  :-\
I'm not sure Tommy, about an XBR in a carbon fibre wrap, but my cousin lives in Castlemartyr, and her fella does wraps for a living, so you never know  ;)
