Author Topic: Cafe racer  (Read 7218 times)
Cafe racer
« on: September 15, 2014, 05:49:37 PM »
Re: Cafe racer
« Reply #1 on: September 15, 2014, 08:51:18 PM »
Not bad, know where there,s a better looking XBR cafe racer :)
Re: Cafe racer
« Reply #2 on: September 16, 2014, 10:37:09 PM »
Aye Propeller,
Nice, but the swinging arm is 'standard' Motrans Ducati/Ducati and more than adequate for the power it is being asked to handle on the road.
Also the extra pipework does nothing for the bike apart from load it up with more weight where you don't need it. Extra rigidity may be an advantage with the old 'narrow case' frames, but on the widecase used by Ducati and adopted under licence by Motrans they are plenty stiff enough. The 100Kg Ducati single is the weight to be aimed for, with a 350 motor tuned for plenty of mid-top range power. Yes, there are fancier bits of kit for the track and the Island, but one of these 350 spring valve widecases (image attached) will provide years of enjoyment.
Shredded rear tyre on narrow case 250 Monza
"Unfortunately, Stu had done a little too much sliding in qualifying and found that his rear tyre was badly worn. The budget didn't run to a replacement so it would have to do for the race."
And you can't have that much fun if the frame is like the Forth Rail Bridge!  ;D
Sadly 'Steelcraft haven't updated their blog in a while, but if you care to see some tasty bits of Italian singles and scratching about on Ducati 250 singles, these 2 Gentlemen have a good idea of how to do it.
'Steelcraft'_Ducati_single_racing_blog
Best wishes and good health, Bill
Attachment Expired
« Last Edit: September 16, 2014, 10:39:47 PM by themoudie »
Re: Cafe racer
« Reply #3 on: September 16, 2014, 10:46:41 PM »
Hi bill.
100kg. Sounds a great motorcycle.
I'm aiming for 100kg on my 250rs. Whether I'll achieve it or not remains to be seen. A long ways off yet. Other projects jostling for time as well.
Cheers, Andrew.
Re: Cafe racer
« Reply #4 on: September 16, 2014, 11:52:29 PM »
Should be good Andrew.
I have a friend whose maximum weight limit for a bike is set at 160Kg, wet. He has a very nice T100, which achieves that!  ;D
Nippy, would be the best way to describe it!  ;)
All the best with all the rebuilds.
Re: Cafe racer
« Reply #5 on: September 26, 2014, 08:38:25 AM »
http://www.bikeexif.com/bmw-k1600#more-18400
My gast is well and truly flabbered.
 :o
Re: Cafe racer
« Reply #6 on: September 26, 2014, 10:10:46 AM »
 :o
While I can appreciate the skill and work that has gone into it, it's not my kind of bike really..
...however on the same page, this is more like it ...
...or this...
« Last Edit: September 26, 2014, 10:31:34 AM by SteveC#222 »
Re: Cafe racer
« Reply #7 on: September 26, 2014, 04:30:08 PM »
Yes I,d have to agree with you on that one Steve. But if you get chance check out the branquart (think I,ve got that right). Honda cbx six. Lovely bit o kit and wot a sound. It,s no ordinary cbx
Re: Cafe racer
« Reply #8 on: September 26, 2014, 05:11:27 PM »
I think its brilliant. The computer cr*p leaves me cold. But as a stylistic exercise it's brilliant. Would I want to own one? If I was filthy rich I'd probably commission one without all the electronic garbage, yes. And park it alongside the confederate fighter and stellan egland harrier. We can all dream! (It's about all I can do on my budget)  ;D
Edit: there are more photos, including some "under the skin" framework, on you tube.
« Last Edit: September 26, 2014, 05:19:32 PM by Propellor »
Re: Cafe racer
« Reply #9 on: September 27, 2014, 10:54:17 AM »
Eh?...Wot?..Pardon?.............I think my ears are bleeding!! :o
Re: Cafe racer
« Reply #10 on: September 27, 2014, 04:07:47 PM »
Worth a spot o blood tho to hear that thing on full chat eh. Just awesome , think it revs to about 20,000 rpm brilliant stuff. Granted not a thumper by anybody,s standard but brilliant all the same
Re: Cafe racer
« Reply #11 on: September 28, 2014, 08:35:54 PM »
Re: Cafe racer
« Reply #12 on: March 21, 2015, 01:23:01 PM »
Re: Cafe racer
« Reply #13 on: March 21, 2015, 02:56:33 PM »
Niiiiiiice!!!
welland99
Re: Cafe racer
« Reply #14 on: April 16, 2015, 09:25:26 PM »
The problem with a bike that sounds like that is that everybody can hear the fluffed gear change!
