Author Topic: Cable making  (Read 3538 times)
guest1406
Cable making
« on: January 05, 2014, 06:26:14 PM »
Hi all,
Ive just made a throttle cable up now just need to solder a nipple on one end, the other end had one. However when trying to coat the tip in solder it just wont stick to it.
Im guessing its dirty? I will try cleaning it with sandpaper and maybe solder grease? Is there something im missing?
Mackenzie
Re: Cable making
« Reply #1 on: January 05, 2014, 06:30:27 PM »
What are you using for heat ?. I found it much easier with a gas powered soldering iron and new inner cables.
guest1406
Re: Cable making
« Reply #2 on: January 05, 2014, 06:46:11 PM »
I was using a gas powered torch, it was heating the cable fine it was glowing red. It just was not sticking for toffee!
Mackenzie
Re: Cable making
« Reply #3 on: January 05, 2014, 07:11:57 PM »
its gotta be pretty much spotless and you need to be using the right flux.
guest1406
Re: Cable making
« Reply #4 on: January 05, 2014, 07:13:59 PM »
It was 3 core flux just to tin it (I think thats the right terms), used for electricals
I'll give it a clean and use grease and see what happens. I really dont fancy making a new cable up
Mackenzie
Re: Cable making
« Reply #5 on: January 05, 2014, 07:28:41 PM »
dont tin it, open the end of the cable out and then solder it into the nipple so when it sets it cant pull back through the nipple
guest1406
Re: Cable making
« Reply #6 on: January 05, 2014, 07:48:13 PM »
I was thinking of that after. But the solder still may no stick to the end of the cable. Or will it now because its open and clean?
Mackenzie
Re: Cable making
« Reply #7 on: January 05, 2014, 08:01:40 PM »
Mackenzie
I had a similar problem and found that heating it using a soldering iron solved the issue.
Re: Cable making
« Reply #8 on: January 05, 2014, 08:12:21 PM »
If its too hot then the flux will just evaporate.
Re: Cable making
« Reply #9 on: January 09, 2014, 06:36:22 AM »
Electrical solder is way not the right stuff. Use acid flux and a harder species of solder. The best way is to melt stick solder in a wee pot (a 3/4" galvanized plumbing end cap is good), assemble the cable and terminal (with cable end splayed to keep the terminal from falling off), heat them, dip in acid flux, Then dip the end in the molten lead until you see some of it wick up the cable.
guest1406
Re: Cable making
« Reply #10 on: January 10, 2014, 02:31:37 PM »
Thanks for the help everyone, its all done now.
I coated the parts in flux, heated the nipple for a bit to heat the core, then brought the fluxed end cable into the flame and heat them both gently, then quickly brought the two together and added solder.
Mackenzie
