Author Topic: SRX 600 Rear wheel bearing part.  (Read 1919 times)
wellesleyboy52
  • New Member
« on: July 16, 2013, 02:15:02 PM »
 Hello everybody,
                            This is a question to anyone in the club who may be able to help me. I am in the process of renewing the rear wheel bearings in my 1988 SRX600 as the ones which were fitted felt a bit grumpy. As I was installing the new bearings with the help of Steves SRX homepage exploded drawings,I noticed there was a small part missing frome the line up on the axle,I checked the parts list and it is called a flange spacer,and is shown as part number 6 on the rear wheel exploded drawing,and butts up to the end of the long spacer in the middle of the axle.
 I have made some enquiries and the part is available,but would take several weeks to arrive,
 and I dont think this weather will last that long. So, if any of you kind souls out there have a spare one that you could bear to be parted from it,I would be very pleased to hear from you.
 The ref.number on Steves part list is No.6 Flange,spacer 33M-25315-00.The Yamaha part number is 90387177Y4.
                                      Many thanks,
                                                            Mel.
guest1670
Re: SRX 600 Rear wheel bearing part.
« Reply #1 on: July 16, 2013, 10:01:40 PM »
Hi
cmsnl are showing this in stock, 11 euros + postage. I've used them before for Honda parts and they certainly don't take weeks to deliver. Looks like it's common to other bikes too, xj900 for example so maybe possible to widen your search?
Good luck
Martin
wellesleyboy52
  • New Member
« Reply #2 on: July 17, 2013, 05:53:45 PM »
  Hello Martin, many thanks for your reply, I had a session on the net and phone and managed to track one down.They said it would be with me in a couple of days or so.
        Cheers,Mel.
