Author Topic: srx600 front brake callipers  (Read 3151 times)
guest668
« on: June 11, 2013, 08:07:40 PM »
hi does any one know if the same brake callipers that are used on the srx 600 are fitted to any other yamaha's ...fzr for example?
many thanks
Re: srx600 front brake callipers
« Reply #1 on: June 11, 2013, 11:09:39 PM »
Aye beezer764,
First port of call should be here: SRX600_Common_parts
This is SteveH's site and well wortha full perusal.
« Reply #2 on: June 12, 2013, 07:42:32 AM »
many thanks
I have a number of spare calipers if you need one. There are a number of late 80's Yamaha's with the same calipers, piston diameters do vary so worth checking before you buy
guest668
« Reply #3 on: June 12, 2013, 05:59:17 PM »
thanks for the replies...thanks for the offer steve i was looking for a front left hand side calliper.......the one i have has a broken and stuck bleed nipple which i havent been able to remove as yet and am wary of drilling it out incase of  doing more damage....so a spare would be handy
« Reply #4 on: June 12, 2013, 06:51:38 PM »
Ok I should have one I will check later
« Reply #5 on: June 12, 2013, 09:01:49 PM »
I have sent you an IM with a link to some photographs of the caliper
