Author Topic: XBR 600 first ride  (Read 6514 times)
XBR 600 first ride
« on: May 30, 2012, 06:49:03 PM »
I rode the XBR 600 for the first time today, its a completely different animal, compared to the old bike, very rorty snorty :) with a lovely crackle on the over run. I put 2 short videos on you tube. Enjoy
&feature=plcp
&feature=plcp
Re: XBR 600 first ride
« Reply #1 on: May 30, 2012, 07:19:53 PM »
The 600 conversion is more than worth the money  :) :)
« Reply #2 on: June 01, 2012, 12:32:34 PM »
I just got back from a longer ride today, the bike behaved its self very well, with no signs of pinking from the high compression. The only downside was a small weep of oil from the rocker cover gasket, and some movement from the head bearings as it settled down, so a little torquing down and adjustment will be required. Carb jetting was spot on, so no need to play around with that, and the methanol / water injection worked ok and kept the engine temperature down. Im extremely pleased with how well things are going.
« Reply #3 on: June 01, 2012, 12:36:30 PM »
Excellent result.  Water/Methanol injection - you sure you haven't built a Bf109 by accident ?
« Reply #4 on: June 01, 2012, 01:45:47 PM »
A lot of 1940's and 50's high performance piston engines used MW injection with spectacular results, but they were also supercharged. Methanol / water doesn't work so well in naturally aspirated engines, but you do get a small increase in performance due to charge cooling, but I was more interested in keeping cylinder head temperatures lower
blew
« Reply #5 on: June 01, 2012, 04:54:54 PM »
I can't really compare my 600 conversion,because the bike was knackered as a 500.I simply used an XL600 barrel and piston.It's torquey,rather than revvy,so I fitted a 16 tooth gearbox sprocket.It feels as if I could get off and walk faster because it's rather effortless.The bike was running rich,probably a worn needle/jet combination,so I fitted a Dominator 650 carb,and the plug colour is much better.My pillion hates it and won't come on it though-too slow,she says.
« Reply #6 on: June 03, 2012, 09:34:45 AM »
Read the service instructions as well as the power figures. If memory serves it was head off every five times the boost was used.  :o
Maybe 1980's Japanese Metalurgy will increase this, but by how much?  ???
« Reply #7 on: June 03, 2012, 10:46:51 AM »
No problems now with head life, lots of modern hot rods and especially pulling tractors injecting vast quantity's of MW with no ill effects. I am injecting relatively small amounts into my naturally aspirated engine, which means cooler denser intake charge, lower head temperatures, reducing the chance of pinking, no exotic fuel mixtures needed and no need to decoke the engine any more
« Reply #8 on: June 03, 2012, 03:52:21 PM »
Suzanne and me went out for a short ride today on the XBR and had a very pleasant afternoon, although a new problem has cropped up with the bike, serious transmission judder at low revs when using the clutch.  Im not sure what might be causing that, has the clutch failed ?. Any ideas anyone?
« Last Edit: June 03, 2012, 04:38:54 PM by JOOLZ »
guest24
« Reply #9 on: June 03, 2012, 09:24:28 PM »
How is your chain adjustment?
Did it only start to happen when two-up?
« Reply #10 on: June 03, 2012, 09:58:17 PM »
Dry Plates....Sticking Plates.
Clutch basket needs dressing with a file.
Springs at the back of clutch basket U.S.
Pull the cover off and have a look.
« Reply #11 on: June 04, 2012, 08:06:26 AM »
Thanks for the advice, I only noticed it 2 up, the chain is properly adjusted. It looks like I may have to strip the clutch, I dressed the clutch basket when I rebuilt the clutch with new plates and springs, Im starting to think it may be the springs on the back of the basket.
« Last Edit: June 04, 2012, 10:35:11 AM by JOOLZ »
« Reply #12 on: June 05, 2012, 10:45:05 AM »
"- you sure you haven't built a Bf109 by accident ?"
If it sounds like this:
&feature=related
Then I want one!  :o 8)
(Warning, audio porn in the above link, your significant other may look at you strangely when you repeatedly play the clip at high volume with a dreamy look on your face!)  ;D
« Reply #13 on: June 06, 2012, 07:05:51 AM »
Ooooh Sounds lovely, no problems in this house with engine sounds, Im always playing youtube videos of engines running, I think Suzanne has resigned herself to that fact
« Reply #14 on: June 07, 2012, 08:27:47 PM »
hi blew i am doing the same thing now to a xbr  was there much improvement with the dommie carb what jets  are you  using and have you got the airbox  or a pod filter,tommy
