Author Topic: SRX400 kick start  (Read 3793 times)
guest1378
SRX400 kick start
« on: November 27, 2011, 05:09:46 PM »
I only had time for a quick poke around with the bike before it got dark but noticed that the kickstart hits the back brake pedal.  I assume the brake pedal is set a little too high and just needs adjusting downwards a bit - Does this sound a reasonable assumption?
guest381
Re: SRX400 kick start
« Reply #1 on: November 28, 2011, 04:54:56 PM »
Yes reasonable but just check if the kick starter stop on the frame is still there.
« Reply #2 on: November 29, 2011, 10:39:22 AM »
I have a spare kickstart stop (or two) if you are missing  this vital piece of your bikes frame. Just ensure that there is not too much play in everything and that the kickstart is on the correct spline. It may also have a kickstart lever off another bike. I will send you a photo or drawing of the original when I get home from work (unless Steve H beats me to it!)
Ian :)
Welcome to the SRX fraternity
1 SRX400 & 1 BMW C400X
« Reply #3 on: November 29, 2011, 09:12:36 PM »
Here is the parts list for the 600 kickstart courtesy of Steve Haywards SRX600 site (Hope he didnt mind my copying it!!!) Dont forget there is a height for the rear brake pedal set from the footrest. (Sorry I dont have a piccy of that but Im sure Bill will possibly be able to oblige). Hope you get it sorted. Im sure one of us will be able to help if you get stuck
HTH
guest1378
« Reply #4 on: November 29, 2011, 09:18:54 PM »
Thanks for that.  I'll have to have a proper look on Friday - I go to work in the dark and come home in the dark!  :(
« Reply #5 on: November 29, 2011, 11:35:06 PM »
HTH
Aye Ian and sfb,
Should be able to, although Sally is fitted with a set of Japanese 'Crane' rearsets [PCWorld ::)], so of no use to you. I have an image and measurements elsewhere.  ;)
We are using snorkels up here at present, and whilst I type this there is a heavy rain/sleet dump ongoing, with squally Force 5 - 6 winds pushing it on. To cap it all, the large snowplough with the brine application equipment has just passed the house at a sedate 'spreading' speed! ???
All the best, Bill.
« Reply #6 on: November 30, 2011, 08:46:43 AM »
Is the brake lever bent or the pivot worn ?
guest1378
« Reply #7 on: December 01, 2011, 09:28:35 PM »
It does have a kick start stop so it looks as if I just have to adjust the brake lever.  Not sure when I'll look at it next - hospital tomorrow, fingers crossed I'll escape tomorrow as well........... :-\
« Reply #8 on: December 01, 2011, 11:20:56 PM »
Here is the info regarding brake pedal height :
HTH
Ian :)
« Reply #9 on: December 02, 2011, 12:17:26 AM »
HTH
Ian :)
Aye ian,
Sent this scan to sfb using message as I'm not sure how to link to image and display in reply! :-\ Will try on this, but it may go wrong!
Regards, Bill.
guest1378
« Reply #10 on: December 04, 2011, 08:43:31 AM »
Thanks guys, the scan worked well! :)
