Author Topic: I bought a bumpstop last week  (Read 861 times)
chippit
« on: July 27, 2011, 06:07:33 AM »
Brilliant bit of kit!
You just roll the bike onto it and it holds the front or back wheel.
If you buy the bars to make the base wider you can use it free standing in a van or trailer. Two straps across the handlebars is all you need.
Both my bikes only have side stands and the morini dart has had a habit of breaking down and trying to fall over, so it has made life so much safer.
There is a version for only a few pounds more that is thatcham approved, you can bolt it down and lock the bike to it.
They are British built using stainless pins/fittings and will last a lifetime (not like the Chinese rubbish  with sharp corners that will cut into your tyres.)
Just thought I would let you know, it is so rare these days to find a well made and designed British product that does exactly what it says.
www.bumpstop.co.uk
I have no trouble loading and unloading the bikes on my own, it has made working on the bikes so much safer, no more balancing the bike on wobbly paddock stands.
Regards Christine
