Author Topic: srx400 cylinder barrel nuts  (Read 2546 times)
guest668
« on: June 06, 2011, 08:00:57 PM »
does anyone know the parts numbers for the front and rear nuts for the cylinder barrel  or where i can get replacements for the srx400/600 theres two of them recessed in the fins...
Re: srx400 cylinder barrel nuts
« Reply #1 on: June 06, 2011, 09:13:44 PM »
Part number is 90179-10201 (2 required).  You should be able to order them from any decent Yamaha dealer if they are still available. If not then it looks like I will have to make some  ;D
1 SRX400 & 1 BMW C400X
« Reply #2 on: June 07, 2011, 06:36:52 AM »
If its the aluminium barrel nuts then I believe they are used on a number of Yamahas, failing that www.kedo.com do stainless steel replacements
guest668
« Reply #3 on: June 07, 2011, 06:39:34 AM »
thanks guys would i be able to get valve guides and seals for the 87 400 from a yamaha dealer to?
« Reply #4 on: June 07, 2011, 10:44:34 PM »
400 Part Numbers
Valve guides - 4H7-11133-10
Circlip- 93440-12052
Seals- 1J7-12119-01
PS all these are the same part numbers for the 600 as well
HTH
guest668
« Reply #5 on: June 08, 2011, 09:47:34 PM »
thamks ian sorry actually its the valve guide oil seals i need is that the last part you listed also do you buy them as a set? where can i get hold of the parts list book for srx400/600?
« Reply #6 on: June 09, 2011, 12:19:12 AM »
The parts list for the 600 is on Steves SRX site
http://www.srx600.net/
The last part number is the valve oil seal (I think you buy them singly) That part number fits a variety of Yamaha bikes/engines/snowmobiles/jetskis etc so should be readily available
