Author Topic: halcyon mirrors  (Read 4212 times)
halcyon mirrors
« on: May 06, 2011, 10:39:38 AM »
I am thinking of buying one of these http://classicpartsltd.com/830-halcyon-bar-end-mirror.html for the SRX (I will have to modify the bar end weight to suit)
They look to be good quality mirrors, has anyone used one and how well do they cope with vibration ?
Re: halcyon mirrors
« Reply #1 on: May 06, 2011, 11:10:59 AM »
I had something similar (though not this make) on my Cossack and they did vibrate quite a bit a 60ish, the rear view was a bit restricted too.  :-\
Furry John
Re: halcyon mirrors
« Reply #2 on: May 06, 2011, 03:45:16 PM »
Hi Steve,
I use mostly handlebar end mirrors and the fitting you have selected is by far the best, just don't tighten it too hard or the throttle will stick on the bar, DAMHIK. You might like to look at the four sided mirror rather than the round, the 4 sided one gives you a much wider field of view behind, from immediately behind out to the overtaking lane just behind out to lane three 400 yards back.
Furry
Here I go again!!
guest146
Re: halcyon mirrors
« Reply #3 on: May 06, 2011, 06:44:46 PM »
Hello
I have these on my Francis Barnett and although very good I had problem keeping them tight not so much the clamps but the socket where mirror fits into the handlebar clamp, Its a sort of groove with a matching part to locate in it.
Regards Ken
Re: halcyon mirrors
« Reply #4 on: May 06, 2011, 08:11:32 PM »
I have the same mirrors on my xbr and they work well, the new fixing system (like a bicycle handle bar clamp) is a great improvment over the original design. You will have to remove the barends to fit them and maybe trim the end back on the twistgrip
Re: halcyon mirrors
« Reply #5 on: May 06, 2011, 09:48:31 PM »
Used on the old Fokker (BMW really) for years and before that on a Cagiva Allazurra.  They work great but please don't fit two.
Re: halcyon mirrors
« Reply #6 on: May 07, 2011, 08:44:48 PM »
Steve...you'll need to remove the bar end weight....least, i did.....anyway, i think the standard srx bar end weights are a bit ugly and don't make any difference....my old bike is as stable as anything...never shakes its head
Re: halcyon mirrors
« Reply #7 on: May 08, 2011, 10:24:57 AM »
I used a Stainless one of these on my 1st Bonnie.
Cant say I had a problem with it at all.
Re: halcyon mirrors
« Reply #8 on: May 11, 2011, 10:50:31 AM »
Cheers for the comments, I've now ordered one. I broke my last mirror 5 or 6 years ago so I'm going to have to learn to use it !.
Re: halcyon mirrors
« Reply #9 on: May 11, 2011, 11:51:42 AM »
Cant ride without mirrors, I like to see whats behind me
guest24
Re: halcyon mirrors
« Reply #10 on: May 16, 2011, 08:54:29 AM »
Do you not worry that it is going to make your bike extra-wide and more difficult to filter in traffic?
Re: halcyon mirrors
« Reply #11 on: May 16, 2011, 12:53:50 PM »
Received it today, a nice bit of kit. It will make the bike wider but since its fairly narrow to start with it hopefully wont be an issue.
guest1166
Re: halcyon mirrors
« Reply #12 on: May 17, 2011, 09:22:58 PM »
That's why i call the ones on ny Srx elbow protectors - when they start bouncing of car mirrors I know to tuck my arms in :o  ;)
pigafetta
Re: halcyon mirrors
« Reply #13 on: May 17, 2011, 10:53:50 PM »
The standard XBR jobs are more like elbow admirers. Your elbows are pretty much all you can see in them.
Re: halcyon mirrors
« Reply #14 on: May 18, 2011, 08:26:59 AM »
You should try the standard ones on a Moto Guzzi T4  :'(
More like glove admirers..
Steff
