Author Topic: Doing the ton on an XBR?  (Read 4613 times)
pigafetta
Re: Doing the ton on an XBR?
« Reply #15 on: March 02, 2011, 09:26:36 AM »
I've had mine up to somewhere between about 95 and a ton depending how accurate the speedo is. I reckon it had a little more to go but it was getting a bit cringey. Not an experience I'll repeat regularly. It'll do 80 2s up.
Dave B
« Reply #16 on: March 02, 2011, 08:37:58 PM »
Mine would do around 125mph without too much trouble. It was stripped down, probably 100lbs lighter, running a TZ upper fairing. Power was around 53bhp @ 8000rpm atw, stock was around 32bhp. Gearing was raised using an XL600 primary drive. Braking was taken care of by a GSXR 4-pot caliper and a 320mm FZR front disc.
