Author Topic: Help!  (Read 1727 times)
sexually oriented
Help!
« on: February 06, 2011, 11:18:43 AM »
Anyone know who uses a Fournales shock and has a pump they wouldn't mind lending me???
Re: Help!
« Reply #1 on: February 06, 2011, 12:40:28 PM »
Just reverse the polarity on your penis enlarger. ;D
Re: Help!
« Reply #2 on: February 06, 2011, 12:44:35 PM »
Not sure I know what your on about, but I've got a pump for adjusting air assisted front forks. Connects via a car valve fixing and has a very accurate pressure gauge.
Furry John
Re: Help!
« Reply #3 on: February 06, 2011, 02:16:40 PM »
HI jules,
Has Jethro sold his, if so he will know who to?
Furry
Here I go again!!
Re: Help!
« Reply #4 on: February 06, 2011, 03:00:28 PM »
i think fournales shocks run at extremely high pressure due to them using the air to act as a spring, so im fairly sure that they need the correct pump to adjust them cos normal airlines dont go gigh enough and front fork air adjustment pumps are designed to add just a very few psi to your suspension, not the 300 or 400psi or so required in the fournales
guest40
Re: Help!
« Reply #5 on: February 06, 2011, 03:02:20 PM »
The pump needs to be able to deliver at least 300psi, albeit at very low volume.
check out the forenales site.
Spot on Johnr
Re: Help!
« Reply #6 on: February 06, 2011, 03:59:02 PM »
I'll shut up then :-[
Re: Help!
« Reply #7 on: February 06, 2011, 04:18:39 PM »
Re: Help!
« Reply #8 on: February 07, 2011, 12:05:13 AM »
Jules has the correct pump.
But is having some trouble at the mo,and wishes to try another to see if that makes a difference.
I expect that his shock would need around 40bar.
I know my 900Divi needed 38bar and my Beemer was around 26-30bar.
A compressor wouldnt look at it !
