Author Topic: XBR fork springs?  (Read 2022 times)
guest833
XBR fork springs?
« on: September 01, 2010, 02:13:31 PM »
Sure it's an easy question but re the long spring inside the fork-
Does the tighter thinner part of the spring go at the top or bottom of the fork on reassembly?
The book doesn't give a clue
John
Re: XBR fork springs?
« Reply #1 on: September 01, 2010, 04:22:05 PM »
Tight tapered end down. ;D
guest833
« Reply #2 on: September 01, 2010, 05:01:23 PM »
Bless you kind sir- you will go to heaven (hopefully not too soon)
John
guest1130
« Reply #3 on: October 03, 2010, 01:58:47 PM »
Mine was the other way around - the tight end of the spring was on the top (closest to the driver) and the looser part on the bottom..
guest833
« Reply #4 on: October 03, 2010, 03:06:06 PM »
any more offers?
« Reply #5 on: October 03, 2010, 03:52:59 PM »
Quote: Official Honda XBR500 Manual section 12-17
"Wipe oil off the spring throughly using a clean cloth
Install the fork spring with the taper ends facing down.
Install the seat washer and spacer in the fork tube."
( However I seem to think that Hagon replacement springs were installed tight coils UP)
