Author Topic: Help to fit a sidecar  (Read 1462 times)
« on: August 18, 2010, 06:42:01 PM »
Yo,
Can anyone give me any info and specs in fitting a sidecar or point me to a relevant website that may be of help.
Ta, Mark
Re: Help to fit a sidecar
« Reply #1 on: August 18, 2010, 10:01:44 PM »
BOO !
Been through several of my fitting guides.
Rule of Thumb is basically.......as there are no hard and fast instructions as it varies from bike to bike and sidecar choice.On top of that personal preference.
Any way they all say basically the same thing.
Distance between motorcycle and sidecar frames should not be greater than 10-14inches
Distance between the center lines of the bike rear wheel and the sidecar wheel(sidecar lead) 8-10inches. Mine is about 12".
Toe in(sidecar wheel pointing towards bike front wheel 1/2-3/4inch. Mine is a full inch maybe a little more...a little too much on mine but does track in a straight line very nicely no effort at all to hold her in a straight line.
Lean out(bike leans out a little) 1/8-1/4 inch. Theory being when sidecar loaded this will bring the bike upright.....Got mine upright,or near as damnit.
Fit the chair and try it....make a few adjustments,but only one at a time and see how it goes.
Do increase tyre pressures by 1 or 2psi.
You will need stronger springs front and back.
Dont be too suprised if it shakes it head upto 30mph.A steering damper maybe needed.
Didnt need one on my Beemer....but do on my Bonnie,same chair.
I will be fitting another chair to my Bonnie when I get the chance,have finished welding the chassis,got to paint it now.
Best of luck.
Jethro.........Its an Adventure ! 17 years on outfits and I still scare myself,occasionally  ;D ;D
« Reply #2 on: August 19, 2010, 07:42:12 AM »
Ta Jethro, excellent, just the info I need.
« Reply #3 on: August 20, 2010, 04:44:28 PM »
Please tell me that the sidecar is not being fitted to the 350 Enfield to accommodate a slumbering Ifor?
« Reply #4 on: August 22, 2010, 06:34:25 PM »
Ha bloody ha,
It's not going on the Enfield(yet, but have had thoughts) gonna put it on a MT350 which is now fitted wiv a 600 motor. But I do now have another sidecar chassis and may fit it to something else.
Ifor is getting excited about going in it and is also considering putting one on his Norton as if it's not slow enough. I heard you need at least 25hp and I don't think his has 10. ;D
Mark y cadair
