Author Topic: Battery elimination  (Read 3347 times)
Battery elimination
« on: April 20, 2010, 07:51:54 PM »
Hi Peeps who understand electric pixieese
I have been given a box of big capacitors to see if any will suffice for the battery elimination gig.
I want to do this on 6v and 12v bikes.
I understand I needs lots of uF - I have variously seen 4500, 16000 and 20000 suggested.
I also understand that I need spare volts on the spec, I have seen 40v suggested for 12v applications.
Now I have here 2 off 85000 uF 16v DC - loads of uF (too many?) but will 16V be sufficiant for a 6V application?
I have several 4500 uF 40v DC - loads of V for 12v but are there enough uF? - can I use two capacitors in parallel and have double the uF at the same V?
Thoughts please
guest146
Re: Battery elimination
« Reply #1 on: April 21, 2010, 05:10:14 PM »
Is a capacitor the normal way of fitting lights to a non battery bike? Its the first time i have heard of this. If you have spare power from you engine generator can you not just pipe min a regulator and a battery?
Bojer
« Reply #2 on: April 21, 2010, 06:51:56 PM »
Yes you can use two of your caps. in parallel to double up the uF but when I have tried similar arrangements or just running a zener diode etc I have found a battery does a good job in comparison ! Try it and see how you get on - add more caps as you feel the need !
I found that a small sealed alarm battery - very similar to the ones used in the work alarms that are replaced regularily  ;) do a great job and hold charge well too , as you'd expect .  8)
« Reply #3 on: April 22, 2010, 09:43:06 AM »
Hummm we get a number of UPS sealed units through - mind I was comparing the weight of a cap with a LA battery...
Bojer
« Reply #4 on: April 22, 2010, 01:31:17 PM »
The cap is smaller and lighter true - I have used one with success - even on a bike that was battery coil ignition it was good enough to run the bike - but low revs with lights or indicators etc would misfire/cut out !
If its for a bike without indicators I think a cap is a good solution especially if its a bike that is not used every day - I should be getting a BSA B40 trials bike soon so might give it a try on that - thanks for the reminder !
« Reply #5 on: April 22, 2010, 02:54:44 PM »
I should be getting a BSA B40 trials bike soon.
Do you compete in Pre-65 trials ?. You sig also says you have a DT, excellent bikes, I used to do long distance trials (not the MCC ones) on the DT.
Bojer
« Reply #6 on: April 22, 2010, 08:28:20 PM »
[/quote]
[/quote]
Not yet ! But that's the plan , been trail riding for a long time and Rallies etc but fancied a change and have never tried trials .  Still have the DT , stripped down and shotblasted the frame and its slowly going back together - as you say great bikes - bought my first one brand new for £659 OTR - shows I AM getting old !
« Reply #7 on: April 23, 2010, 11:34:31 AM »
Fancy a DT250 / 400 chassis for a Maico lump I have hanging about - Used to have a 125, a 157 and a 250 - all great bikes
« Reply #8 on: April 23, 2010, 12:20:07 PM »
Embarrassingly my DT175 is stored in the loft. Haven't the heart to sell it, and since its been hacked about quite a bit with trials mods, its not worth much anyway.
