Technical
Bike Problems/Questions
CB250RS Chassis + XBR500 motor = ?
Topic: CB250RS Chassis + XBR500 motor = ? (Read 3825 times)
April 10, 2010, 07:24:55 PM »
Anyone had any experience of, or thoughts on, marrying a CB250RS chassis with an XBR500 motor? Have read often about putting XL500 motors in the RS but they are almost akin to the Dodo these days!
Re: CB250RS Chassis + XBR500 motor = ?
April 11, 2010, 09:30:43 AM »
Aye Boyd,
Maybe this engine conversion might be the answer? Currently on Fleabay, (Lot: 130379035478) link follows:
CBR300RS
Fairing and paintwork are 'Naff' in my humble opinion
, but the rest would be interesting. Starting might be a problem!
Off to play!
Bye Bye, Bill.
April 11, 2010, 10:06:25 AM »
If you still have the Winter2003 'Thumper' magazine, there is a big article on Steve H's CB500RS. He used the XL/FT500 engine. I would have thought that size wise the XBR will be very similar as it's based on the XL. Your biggest problem will be how/where to fit the oil tank. You might be able to rig something up where the air box sits and then use a K&N filter? It'll be an intersting bit of kit if you manage it!!
April 11, 2010, 12:04:07 PM »
I'm pretty sure that the XBR engine will be too big. There was a guy who raced a 300cc Yoshi converted RS back in the eighties, it was a very quick motor.
April 11, 2010, 12:17:51 PM »
Quote from: Rhinoman on April 11, 2010, 12:04:07 PM
Is the RFVC head significantly taller than the earlier non-RFVC heads ?
Reply #5 on:
April 11, 2010, 01:11:46 PM »
As the engine is dry sump, wouldn't the the sump be shallower than a wet sump (XL/FT etc) engine? if so this should reduce the overall hight?
Reply #6 on:
April 15, 2010, 09:14:54 PM »
I think the engine is a lot beefier all round, its a much stronger design than the old FT/XL500. I can take some measurements if you like.
paulp2655
Reply #7 on:
April 18, 2010, 02:56:13 PM »
Inspite of the engineering issues, it does sound like a very good idea.
el vencejo
Reply #8 on:
April 18, 2010, 03:34:54 PM »
I always like big motors in little chassis, sounds a worthwhile project
The Euro VTR250 looks ideal for an aircooled 600/650 RFVC motor (when they've been around long enough to suit my locked wallet)
The XBR 500 and Dominator-to-FMX 650 motors are almost identical externally; similar power but lots more torque on the big 'uns. Depends what lights your candle
Technical
