Author Topic: may need a bit of advice from SteveH....  (Read 1477 times)
« on: February 17, 2010, 05:10:27 PM »
Steve, I (thought) have posted a some pics up into members area (bikes and projects) it says i've used up my allowable space, but i can't see them anywhere.....I'm almost certainly being a complete waste of space......can you sort me out?
Re: may need a bit of advice from SteveH....
« Reply #1 on: February 17, 2010, 07:02:41 PM »
Please Sir! Please Sir! ..................................................I can't even see any photo or POTD section. I only get the forum section as my Thumper Club 'home page'. Are there gremlins or is it just me, Sir?
« Reply #2 on: February 17, 2010, 07:10:22 PM »
Boyd, trying loading the site using the basic URL www.thumperclub.com, that should display the home page with all the options. I too have been having issues with just the forum pages being displayed.
« Reply #3 on: February 17, 2010, 07:15:24 PM »
Cheers Graham
Needed to add    /drupal/    to the end, and now all is OK again!
« Reply #4 on: February 17, 2010, 09:49:00 PM »
If you are using the http://www.thumperclub.com/smf/ URL then it will only show the forum. Best bet as Graham says is use www.thumperclub.com or if you want to go straight to the forum use http://www.thumperclub.com/drupal/smfforum.
I put a redirect in for all the other pages which moved but couldnt do it for the forum.
« Last Edit: February 17, 2010, 09:59:54 PM by Steve H »
« Reply #5 on: February 17, 2010, 10:03:50 PM »
I have updated a few config values which should hopefully help. I have tried uploading a photo, it uploads the photo then gives an error right at the end. If you then go back to www.thumperclub.com and look in the Galleries you should still be able to see the photo.
The Gallery is still in Beta, there is a new build available so I'll upgrade the version we are using at some point.
« Reply #6 on: February 17, 2010, 10:50:01 PM »
OK Steve...top bloke.......
« Reply #7 on: February 17, 2010, 11:29:24 PM »
thanks Steve....pics went up into projects area ok....did get an exception error for each one, but they went in ok and are visible.
