Author Topic: Wrong stroke, too many cylinders, but...  (Read 39056 times)
Re: Wrong stroke, too many cylinders, but...
« Reply #60 on: January 29, 2010, 12:23:55 AM »
Mind you don't get oil on your anorak !
Rob
Sod Off !
« Reply #61 on: January 29, 2010, 07:53:23 AM »
Bloody hell.  I hope you realise that a two stroke multi has generated more discussion on the thumper list than any other bike for ages.
« Reply #62 on: January 29, 2010, 06:01:05 PM »
Have Jet sizes and oil info !
Let me know which model.
Cheers for that. At first Google the model appears to be called a 350 Type 638.5. but I will keep checking
It looks exactly like this one (which apparently is a Type 638):
« Reply #63 on: January 29, 2010, 06:33:30 PM »
Aaargh, not the dreaded combined gearlever/kickstart ?
« Reply #64 on: January 29, 2010, 06:38:55 PM »
Oooooh Yes!
robG
« Reply #65 on: January 29, 2010, 10:39:47 PM »
If you turn it the opposite way, it makes a noise like a barrel organ............That reminds me of a song about a girl from Glamorgan..... ;D :D
Rob.
« Reply #66 on: January 29, 2010, 10:41:27 PM »
That also operates the clutch.....bit like the Triumph Slick Shift of days gone by !
« Reply #67 on: January 30, 2010, 01:19:33 AM »
Check out this version:
the phrase 'polishing a turd' comes to mind, but it does look very pretty  ;)
« Reply #68 on: January 30, 2010, 10:04:14 AM »
Spoiling a perfectly good motorcycle with distasteful paintwork more likely.
If you fail to get it running I might be willing to make you a modest offer for the bike but strictly without the peg-leg.
« Reply #69 on: January 30, 2010, 04:08:33 PM »
Sorry to say Steffan, it runs and my brother keeps belting it up and down his lane to 'just test the gears' (he's such a child  ;)). What he actually tests is his sphincter each time he uses the front 'brake'.
We agreed today to shelve it as a Dragon ride, he felt that it was too little time to test it out. Jethro said much the same to me last night on the phone and if he knows about anything it's the bad things that happen when Eastern European two strokes let you down. He once dismounted at 70mph on the motorway when an MZ seized  :o :o :o
The CB500 sailed through its MOT this morning. I met RobG in the bike shop, he was getting his XS1100 behemoth MOT'd too.
« Reply #70 on: January 30, 2010, 04:28:28 PM »
That's the kind of broad-minded, good-natured forum it is  :)
Also, we seem to like quirky tat.
« Reply #71 on: January 30, 2010, 05:00:18 PM »
Ah I see the chair is on the 'interesting' side - to overtake nose the chair out  and judge by the passengers expression if the road is clear or not!!  :o  ( I've been in the chair and done that!)
« Reply #72 on: January 30, 2010, 05:18:32 PM »
If the passenger is screaming you've probably got time to react. When Jethro parked his Velorex under a car (with me in the sidecar) I didn't even see it coming... I just woke up in hospital wondering what the hell happened.
« Reply #73 on: January 30, 2010, 05:36:10 PM »
What's scaring me is the fact that I keep seeing this photo and thinking it looks cute  :o :o :o :o
Then I starting thinking "I could fit an XBR engine in there"  :D :D :D
« Reply #74 on: January 30, 2010, 11:03:22 PM »
But why wreck a perfectly good bike ?
If you said you could fit an XBR brake then I might have some sympathy.............
