Author Topic: Ooh, its running again!  (Read 960 times)
guest24
« on: November 14, 2009, 04:52:10 PM »
My SRX400 is running again! Last ran June 2008, and given bed rest as it required some work. Out of curiosity I charged the battery yesterday and pressed the button. The old beast only started, didn't it!! :D  Stopped shortly afterwards as the petrol in the carbs ran out and the stuff in the tank was not coming through. Awesome result though!
So, wallet is now out  :'(  and necessary bits are being purchased. Just got 2 new throttle cables off fleabay and will be posting my CV slider off to NRP for a new diaphragm. Current diaphragm is a tad stiff and once the slide is rising past half-way, it doesn't want to stop and the revs rise on their own against a closed throttle..eek. Just need a new front sprocket, oil & filter change and then a road test. Oh, and cure the rust problem in the fuel tank, again. grrr.
Re: Ooh, its running again!
« Reply #1 on: November 14, 2009, 10:01:17 PM »
Well done Bruce :), hope the parts list has come in handy
1 BMW C400X
« Reply #2 on: November 15, 2009, 10:12:28 AM »
Will you be using this as a winter hack rather than the MT03?
guest24
« Reply #3 on: November 15, 2009, 10:15:04 PM »
Ian, yes it has and will - many thanks!!
As regards a winter hack, nah. I think it will be pot lock in the morning as to which key comes out the pocket first...haha.
However fixing is going to be a bit of a struggle as the fuel tank has gone a bit rusty inside again and thats after Andy fixed it for me 2 years ago. I suppose leaving old fuel to fester is never good. Wonder if fleabay will ever produce a good example sans rust...?
« Reply #4 on: November 15, 2009, 10:29:24 PM »
is it the monoshock variety...if so i have 2 tanks......although a tad rusty probably not as bad as yours
guest24
« Reply #5 on: November 15, 2009, 10:43:38 PM »
My tank is in lovely condition externally and feels solid all over underneath even with a good amount of tapping with a screwdriver handle ie no dull crunchy sounds!
It is a monoshock of 3VN1 1990 vintage, in black. There should be a couple of photos appearing in the pictures section of it running with its fuel tank bypass device attached...
What colour are your tanks and how much?
