Author Topic: Weekend Debrief  (Read 3554 times)
Re: Weekend Debrief
« Reply #15 on: November 10, 2009, 07:42:03 AM »
That only gets the air out upto the calliper (duh). Getting it out of the calliper itself without a bleed nipple is bloody hard. Trust me I know. >:(
Its works if the banjo is near the top or you take the caliper off and arrange it so it is.
Re: Weekend Debrief
« Reply #16 on: November 10, 2009, 09:17:02 AM »
Rotate bike so the banjo is at the top, prop with wood or Squirrel Minors for a nicght and then bleed...
Simon#83
Re: Weekend Debrief
« Reply #17 on: November 10, 2009, 12:12:43 PM »
...................The guy on the Blue Tenere showed us that they crash really well and don't damage too much! :o
Hopefully picked the right colour for mine then  ;D
Simon
KTM Duke II
Royal Enfield Himalayan
KirriePete
Re: Weekend Debrief
« Reply #18 on: November 11, 2009, 01:01:32 PM »
Remove caliper from fork leg, remove pads, pump piston almost all the way out, rotate caliper so banjo is at the highest point, gently push piston back in while watching reservoir level, watch bubbles come out of reservoir.
Seemples!
(note from moderator - non UK members might want to search YouTube for 'Compare the Meerkat' for an explanation)
« Last Edit: November 11, 2009, 06:30:52 PM by onepot »
Re: Weekend Debrief
« Reply #19 on: November 11, 2009, 07:38:22 PM »
... or order the an 8mm bleed nipple and do a proper job. Even simpler ;D
