Author Topic: A "special" or a bridge too far?  (Read 5887 times)
« on: September 10, 2009, 09:31:25 PM »
Hi one and all...Im relatively new to the forum and Im usually building a bike rather than writing about them, but this time I may need some help, technical info or other advice. Im thinking of building a sort of special but some of you wizards will probably laugh. I have been offered some SRX parts including a few twinshock frames and a "good" monoshock engine including oil tank(I dont know the specific model numbers but Im sure someone on here will be able to rattle them off!)
Questions
1) Is this a viable project without too many mods, or am I living in a dreamworld? as I dont remember seeing anyone trying this before?
2) number 1 is the only one I have at the moment as I havent started just yet..Im just sort of dipping my toe in the water at the mo.
Any help, guidance, direction, information  or other will be gratefully appreciated (either by pm or in open forum)
Thanks in advance
Ian R
My previous effort at rebuilding an SRX 4 wasnt too bad....It was sold to TJ63 earlier this year
http://www.thumperclub.com/smf/index.php?topic=3113.0
1 BMW C400X
guest24
Re: A "special" or a bridge too far?
« Reply #1 on: September 10, 2009, 09:43:45 PM »
Nah, you dont want the monoshock engine, horrible things. As you dont want it, I may be interested in taking it off your hands as it will replace my knackered one (starter clutch very suspect) .... though it all depends on where you are, if you are willing to part with it, and how much. That is assuming it really is a good one?!
Oh, I'm in Hackbridge and thats in Souffff Lundon
« Reply #2 on: September 10, 2009, 09:57:27 PM »
You will find that the watercooled xt600 engine has been put into a twinshock frame as has an electric start monoshock engine, have a look through some of the Holland pictures!
« Reply #3 on: September 10, 2009, 10:02:54 PM »
Thanks for comments so far..I will look up said photos :)
1 BMW C400X
« Reply #4 on: September 11, 2009, 03:02:59 PM »
hello mate
projects!  always good!
The monoshock (lecky start motor) will go into the twinshock frame, but (I think) the sprocket is offset by about 8mm.  Not insurmountable, but you may need to get a bit clever with custom sprockets.
I think the 660 motor has slightly offset lower engine mounts, also requires a bit of cleverness!
And the waterpump on the front of the supremely ugly 660 motor will also foul the front RH downtube on the twinshock SRX frame.  Indeed the crafty dutchman has done it (its a peach) but you'll need to fabricate a kink in the tube (but it unbolts, so its all good)
good luck!
« Reply #5 on: September 11, 2009, 05:55:49 PM »
As far as I recall they never made a water cooled XT600 motor. The water cooled derivative was a 660 or 659 to be precise.
« Reply #6 on: September 11, 2009, 06:30:58 PM »
To be Precise, they never SOLD or offered for sale a water cooled 600, who knows what they made in the workshop?
srx6
« Reply #7 on: September 12, 2009, 08:23:30 AM »
See picture of the day.
Alan
« Reply #8 on: September 12, 2009, 01:11:45 PM »
andy230 is right, there is a sprocket offset (10mm) you can get a sprocket made up at little expense, but as it has been said, 'orrible engine.......too many things to go wrong (and often do)
stick an aircooled engine in there....srx or xt..much better
« Reply #9 on: September 12, 2009, 05:24:27 PM »
 SteveL; i'll second that.
 the xt air cooled 600 is a far nicer engine than the 660 water cooled lump.
the 660 has to be revved to work, and then feels horrible when you do so. the 600 is a lovely thumper that can pull from low-down and is what most people want from a single.
« Reply #10 on: September 12, 2009, 09:02:06 PM »
Hmmmm, perhaps I have been out of a project too long, but the thread of this thread seems to have astray? ???
I originally asked if the Monoshock SRX400 engine would go into the SRX 4/600 Twinshock frame, without too many mods.
After having looked at the 2 engines today I see there is approx 15m/m difference between the (sprocket centres) to the (centreline of the crankcases) measurement
ie Twinshock sprocket   - 90 m/m
    Monoshock sprocket  -105 m/m
(measured from engine c/line to outside of sprockets)
These are approximate measurements and need to be verified with the engine and rear sprocket/rear wheel in the frame with wheels aligned..... Its looking awkward already  :-\
1 BMW C400X
« Reply #11 on: September 13, 2009, 09:33:08 AM »
Astray! Your lucky Ian, some of us go 'walkabout' pretty regular and lateral mental leeping at indeterminate intervals. ::) Hang in there, you'll get the answers and the sympathy vote, if required!
Toodle pip, Bill.
guest24
« Reply #12 on: September 13, 2009, 02:57:40 PM »
My interest in your SRX400 monoshock engine still stands, you know! Especially now as it doesn't fit...
« Reply #13 on: September 13, 2009, 06:51:53 PM »
Lets wait and see......in the mean time how about me buying your knackered monoshock bike complete? Now that sounds more realistic! and Im sure I could do something with it  ;D ;) ;D
Contact me direct  07970979001/07722921222
1 BMW C400X
« Reply #14 on: September 15, 2009, 11:09:53 PM »
Bump!
1 BMW C400X
