Author Topic: One for the sidecar boys  (Read 2363 times)
guest146
« on: May 12, 2009, 09:53:20 AM »
Have a look at this. This chap is one of out drivers and made this himself. Powered by a 1700 ISSUSI diesel from an Astra and driving direct from the gearbox to the back wheel by just  one driveshaft. Although he used to be a mechanic its quiet a project.
http://www.sidecar.freeuk.com/gallerybaker.htm
Re: One for the sidecar boys
« Reply #1 on: May 12, 2009, 10:27:22 AM »
"nine gallon fuel tank"  :o combine that with a diesel engine that won't even be trying and I suspect his range is exceptional!!
Awesome bit of work, now *that* is a winter rally outfit! Would love to see some pics minus bodywork to get a handle on how the back half is built.
Mega. Thanks  :)
« Reply #2 on: May 12, 2009, 11:19:26 AM »
Mmmm interesting take on the hand change - pull away select top and ride I guess
guest146
« Reply #3 on: May 13, 2009, 09:49:41 AM »
If i have done this correctly here are 2 pictures of the sidecar under construction showing the engine and drive
« Reply #4 on: May 13, 2009, 11:51:24 AM »
mmmmmm
So has he used the drive shaft off the 'motor' to the 'bike' wheel, locked off the steering etc - guess this allows adjustment and a later fitting of rearwheel steer (ulp!) but is it driving the 'chair' wheel too?  Seems not, so would that mean sticking a spanner in the diff or something?
guest146
« Reply #5 on: May 14, 2009, 09:37:51 AM »
Hi No all you do is weld up the plannet wheels in the diff so it only turns on one side. I was away from work when he brought it round but i do know it drives direct to the rear wheel from the astra gearbox drivshaft.
« Reply #6 on: May 14, 2009, 09:44:36 AM »
Ahhhhhhh  ???  Think I understand now.
R  ;D
« Reply #7 on: May 14, 2009, 11:17:34 AM »
i would have thought that a driven sidecar wheel with a diff would have been an advantage?
« Reply #8 on: May 14, 2009, 01:50:32 PM »
Would have thought so - but maybe there are problems in keeping it as a sidecar not a trike?  Or the reason the lump was up for use was damage to the gearbox?  Who knows
« Reply #9 on: May 14, 2009, 03:15:41 PM »
Don't forget that outfits generally require the sidecar wheel to be ahead of the rear wheel, not in line.
tj63
« Reply #10 on: May 14, 2009, 03:30:20 PM »
Do you know, I'd never noticed that before.  Hooray - there are still new things even at the age of 54!
Trevor
