Author Topic: srx 400 misfires  (Read 1770 times)
william
srx 400 misfires
« on: December 12, 2008, 09:20:51 PM »
had a problem with starting cleaned the carb starts first kick now another problem bike backfires at high revs and starts to miss and cut out when idleing any help any one pelase
Re: srx 400 misfires
« Reply #1 on: December 12, 2008, 10:07:07 PM »
Aye William,
Air leaks around the inlet rubbers between the carbs and the head?
Start the b***** up and spray some WD40 about opening and closing the throttle. If there are leaks you should soon find them.
If it is in the carb then I haven't needed to play about with mine, so far, touch wood!
I hope this helps.
Regards, Bill.
william
« Reply #2 on: December 13, 2008, 09:03:46 AM »
i will try that
 thanks
