Author Topic: Plywood bending  (Read 1831 times)
Plywood bending
« on: June 01, 2008, 08:23:01 PM »
Hi All
Nowt to do with thumpers - unless I am looking to make a plywood chassis....
Bending plywood so it holds its shape - rather than bending round formers.  Can I do this likie 'normal' wood with a load of steam / ammonia / heat, or do I need to laminate the part from thin single ply?
Looking to make a wooden bike 'guard and it needs to follow a shallow S shape.
Re: Plywood bending
« Reply #1 on: June 02, 2008, 06:34:56 AM »
I suggest you make by gluing up thin veneer into the shape you want rather than try bending an already formed flat sheet of ply. The glue used in the construction of the sheet will not want to allow any movement between layers of veneer.
Re: Plywood bending
« Reply #2 on: June 02, 2008, 10:21:32 AM »
Rats I thought that would be the answer...
Re: Plywood bending
« Reply #3 on: June 02, 2008, 07:38:06 PM »
Aye Pat,
Rogers not disappointed then ;D
Regards, Bill.
Re: Plywood bending
« Reply #4 on: June 05, 2008, 09:52:46 PM »
Have a look at boat-building websites and do a search using the keywords 'tortured plywood' (No, I'm not joking).
If you have two planes to the shape then you can use the one to force a curve (or even a double curve) on the other.
guest40
Re: Plywood bending
« Reply #5 on: June 07, 2008, 02:35:37 AM »
One Pot wrote "If you have two planes to the shape then you can use the one to force a curve (or even a double curve) on the other"
Note, thats a regional method, very popular around Woddington, Farnsborough and Biggen.
Re: Plywood bending
« Reply #6 on: June 11, 2008, 11:48:19 AM »
If you google it don't forget the PLY bit. For Tortured Wood you get some sort of iffy Mills and Boon links plus some you wouldn't want to open at work  :o
