Author Topic: gaskets  (Read 2179 times)
OMEGAMAN
gaskets
« on: March 02, 2008, 10:12:49 PM »
Do I recall seing a debate on this site a while ago about the use of used head gaskets?
I have my race engine to build & have a few decent looking (undamaged) used head gaskets + 1 base gasket that came with it.
Money is running out fast & although it would be nice to use new stuff everywhere, I think? there was an article where somebody mentioned that they painted the gasket with (aluminium?) paint & it worked fine!
Any advice on this is welcome,  ASAP please as time is running out fast!
ps. IF, I have to buy new ones.........WHERE????     & how much should I be paying?
Re: gaskets
« Reply #1 on: March 02, 2008, 10:52:20 PM »
I re-use copper head gaskets, no problems after annealing, haven't tried any other sorts though  ???
Re: gaskets
« Reply #2 on: March 03, 2008, 08:04:16 AM »
If its a Yamaha 600 single then the best approach is a genuine Yamaha gasket, Fowlers willl have them in stock. Not cheap but less hassle than having to strip it again.
Re: gaskets
« Reply #3 on: March 03, 2008, 08:23:50 AM »
The excellent mechanic who did my GB used aluminium paint on the old gasket and it's fine. A new one is very pricey. Let it dry a bit before refitting it. Needless to add, it has to be petrol-proof paint.
Re: gaskets
« Reply #4 on: March 03, 2008, 08:51:38 AM »
Might be ok for the road, but with a high compression piston and being razzed around a track at high revs, it might not stand up quite so well.
Re: gaskets
« Reply #5 on: March 03, 2008, 09:02:18 AM »
Don't people just cut out old cornflakes packets any more ?  If you're feeling flash then you could even slice up an old Coca Cola can and anneal it on the stove.
Pah.  I don't need no steenkin head gasket...............head gaskets are for pussies man.
With a hi-compression head even I, cheapskate that I am, would use a real one.  With a two stroke I would risk it as they are so fast to swap, but not an OHC jobby - too much hassle to swap.
OMEGAMAN
Re: gaskets
« Reply #6 on: March 03, 2008, 01:22:35 PM »
Cheers for that, a genuine new one it is then! (ouch!)
OMEGAMAN
Re: gaskets
« Reply #7 on: March 03, 2008, 05:42:32 PM »
Apparently,the std. Yam (608cc) would be too small for a tuned (630cc) engine, say's Fowlers!
So I'm back to square one...... :'(
Re: gaskets
« Reply #8 on: March 03, 2008, 10:28:03 PM »
Wiseco special ??? Speak with Andy230. I'm little help, as I reduced bore from 634 to 598.
Hope you get fixed, Bill.
guest146
Re: gaskets
« Reply #9 on: March 04, 2008, 12:56:01 PM »
Using Cardboard to make a gasket is OK but if the thickness is not important you may as well use instant gasket. As for a head gasket if its perfectly flat and has not been tightend onto a surface with rings cut in it to make it seal you may get away with re using it although i would be more carefull on a water cooled engine. Apart from making it look good I cant see how using aluminum paint would help as paint has no substance when given combustion pressures.
