Author Topic: Very long shot, non-thumper  (Read 1350 times)
« on: February 18, 2008, 10:31:46 AM »
Does anyone have a Diesel Injection pump timing kit for Lucas CAV pumps they would be prepared to loan/hire me. I need to change the injection pump on my Citroen ZX, and will need to tool to time it in correctly.
guest146
Re: Very long shot, non-thumper
« Reply #1 on: February 18, 2008, 03:10:06 PM »
I may be able to help. If its the Citeron it is the Peugeot engine and from memory its just 8mm short bolts for the pump and cam and a pin of about 5 or 6 mm for the flywheel.
Send me your email and the year and engine type and I will send details from autodata.
« Reply #2 on: February 18, 2008, 03:27:19 PM »
Ken, cheers for that. Your right, to lock up the flywheel cam and pump its three bolts. What I'm after is the dial gauge etc that fits into the pump, so I can set the pump timing correctly.
guest146
« Reply #3 on: February 18, 2008, 04:09:22 PM »
I have the adapator for the bosch pump but I think the CAV goes in the top and its a bit tricky. If your fitting a S/H pump you could mark it as it comes of the old engine and fit to yours in the same place as the pulley is keyed and the blocks will be standard.
Just a thought but depending on the year of your car it may have a chip to prevent theft and if so will need to be programed.
This is it
http://www.sealey-tools.co.uk/parts/VS1131.PDF
guest146
« Reply #4 on: February 19, 2008, 05:29:06 PM »
If your still in need give me a call I can have use of a setting tool.
« Reply #5 on: February 20, 2008, 08:24:56 AM »
Ken, thats the tool. My original plan was to change the pump, however Ive found somewhere that will just repair the seal. Hopefully this means if I carefully mark the mounting plate I should be able to refit in the same position. If this doesnt work I may take you up on your offer.
Steve
guest146
« Reply #6 on: February 20, 2008, 04:49:23 PM »
No Prob
You probaly will change it but dont reuse the old cam belt.
