Author Topic: Central Heating  (Read 872 times)
Central Heating
« on: December 29, 2007, 02:25:25 PM »
Hi All
Long time back someone gave good advice on central heating on here - mind I have done nowt witht he suggestions yet... ooops.
However.  Inlaws house is heated by a Trianco solid fuel boiler - and a fine job it does, however following recent events sister in law has to go round at least once a day to top up the coal hopper.  A few years ago they did have a calor boiler and a bloody big tank put in but the house never got warm.  My guess is the boiler was the wrong spec.  The house id a large detached 4 bed with solid brick walls.  I do not know but I guess the heating engineer looked and thought well insulated cavity etc.
When the gas boiler was put in there was no local mains gas, but there is now a great big garden centre next to them so that may be an option.
Questions: Is there any good reason why a coal fired boiler will get the house hotter than a gas one (MiL tends to have the heating on full and constant) apart from underspec on the boiler?
Do mains gas boilers work better - hotter - more effective than calor?
Would oil be an altenrative?
Any suggestions please - cannot see MiL wanting to move from the place - she has lived there for over 50 years - but it would be good to come up with an option that a disabled 75 YO woman can handle.
Thanks in advance
Bruce
Re: Central Heating
« Reply #1 on: December 29, 2007, 03:54:40 PM »
Cant help with the heating question But is the house roof insulated to modern standards she might be able to get a grant from the local council to upgrade the loft insulaton this can make a lot of difference even if a grant is not available the cost of roof insulation is not high.I have 9" of loft insulation in my little house.
Re: Central Heating
« Reply #2 on: December 29, 2007, 09:04:00 PM »
Aye Rog,
My wee place is an old cotters cottage with concrete floors in all rooms apart from the floorboards laid on half sawn larch bearers laid directly onto the ground in the living room. Walls are 2' thick rubble stone walls behind plasterboard with a 50mm air gap and no insulation between. They 'hoover' heat! ???
200mm insulation in the loft and make sure you keep it back from the eaves so that air can circulate above it. Put reflecting bubblewrap down the back of the radiators, so you don't heat the walls, valves on the radiators apart from the one in the bathroom, this ensures a cushty warm bathroom acts as a safety for the boiler and you can control which rooms get heated and which are kept aired. If you have concrete floors, try and insulate them and if you have drafty floorboards, hardboard does a good job of keeping the drafts out.
My woodburner gives off good radiant heat but also heats the fabric of the house [fireplace and stone chimmney] big heat sink, which then gives up this heat slowly through the house when the stove is out. Same applies I would suggest with your coal fire. Current gas boilers flu just vents to atmosphere and provides no heat sink with which to mop up 'exhaust' heat.
LPG very expensive and if under spec'd a disaster. Run a mains gas boiler of the correct capacity. Not sure about the combi boilers, if the power goes off your stuffed, with no hot water as it heats water 'on demand'. Whereas the ordinary condensing boiler can run at 90% efficiency [heat taken from 'exhaust' in condensation process] and heats water in a separate tank, so if a power cut occours, you still have hot water.
Other combinations of heating the water are numerous, but I suspect you're not looking for major upheavels.
See if SteveL comes on line, he has a plumber mate [#3 owner] and could probably give some good basic advise.
