Author Topic: NEW PROJECT (BUT NOT A THUMPER)  (Read 85570 times)
Re: NEW PROJECT (BUT NOT A THUMPER)
« Reply #120 on: June 05, 2026, 12:19:10 PM »
MOT passed today and the bike runs great. Even the brakes are improving with use....
But I have a persistent fuel leak which has spoiled the overall joy.
I'm advised it's likely to be the float bowl gaskets so a new set is on order.
« Reply #121 on: June 05, 2026, 03:26:50 PM »
Brilliant news Martin. Fuel leak aside.
I hope, given all the hard work and grief it’s given you over the last few months that the sun shines this weekend and you can get out for a decent spin on it🤞
« Reply #122 on: June 06, 2026, 11:41:24 AM »
Thanks Michael.
The leak's quite bad so I decided not to tax the bike yet.
Parts should arrive next week so I'll be back on it then.
Weather here is very mixed so I'm off to Shelsley Walsh this afternoon (in the car).
« Reply #123 on: June 12, 2026, 11:08:56 AM »
Gaskets arrived. Stripped and re-assembled yet again.
Rain stopped play.....again...all good so far. Awaiting read test...
« Reply #124 on: June 12, 2026, 11:18:50 AM »
Read test better than road test in yesterday's weather......
« Reply #125 on: June 12, 2026, 01:46:35 PM »
Damn predictive text....you have to double check everything...
Weather is now better so I've ventured out. It's very quick for a 400 or it might be down to my age?
Seems faster than my CBR600?
No fuel leaks anyway...but temperature gauge issues now. I did 15 miles and it was creeping up to the red zone. Coolant level is ok so further investigation is needed.
« Reply #126 on: June 23, 2026, 04:55:24 PM »
I'm still having a few recommissioning problems.
The temperature gauge now seems to be behaving itself but I've rigged up a manual override switch for the fan just in case.
I've also still got the occasional fuel leak which is due to using old pipes.
Finally there seems to be a misfire which occurs intermittently so this needs further investigation.
When it's running well this is a very impressive machine but I hope I can resolve these few remaining difficulties.
« Reply #127 on: June 23, 2026, 07:13:31 PM »
Yes, with all the hassle you’ve had with it to get it this far. You deserve it to run well/sweetly so you can hopefully enjoy the fruits of your labour
Fingers crossed for you Martin 🤞
« Reply #128 on: June 24, 2026, 06:45:15 AM »
Thanks Michael for all the encouragement and interest ,it's very much appreciated.
« Reply #129 on: July 03, 2026, 05:51:56 PM »
Latest news is a noise which developed in the transmission last weekend.
Turns out the cush drive rubbers were knackered as was the sprocket carrier bearing.
New parts were ordered but the bearing was the wrong size so I had to buy a used sprocket carrier with a nice smooth action and all is well at the moment.
« Reply #130 on: July 07, 2026, 04:09:37 PM »
Been out today and the speedo packed up within 3 miles followed by a worsening misfire after about 15 miles.
Upon checking the speedo cable is broken.
The misfire caused me to stop at the roadside eventually just as the engine cut out.
Checks revealed there was fuel in the tank and the engine started as soon as I lifted the fuel cap so a blocked breather is suspected.
« Reply #131 on: July 07, 2026, 05:33:00 PM »
Holy smokes Martin, it’s a never ending story of hassle with that little 400. Hope the fuel issue is an easy fix 🤞
Cheers…Michael
« Reply #132 on: July 08, 2026, 09:01:05 AM »
As I've probably mentioned I had no end of problems with the little 400 4 I had briefly. Eventually tracked down to a defective plug cap although the vacuum fuel tap was also problematic. Probably no help to you......
« Reply #133 on: July 08, 2026, 12:28:54 PM »
Thanks Ian.
I think I've had problems with most aspects of this project including the fuel tap (leaking but repaired with a kit from NRP Diaphrams which required rivets drilling out and tiny new threads being cut,beyond my limited skill set) buying the wrong type of NGK plug caps for the tiny aperture they live in and then struggling to remove them to put in the correct type.
Some of the other problems have been mentioned earlier in this thread.
I found lots of debris inside the fuel filler area which have blocked the tank breather. It's been vacuumed out now hopefully.
A brief test ride went well this morning and I intend to venture further afield in the coming days.
These problems cannot be laid at the door of Mr. Honda as my bike has been through the hands of numerous owners most if not all of whom probably did little if any maintenance. My bike is now 37 years old so after all the work which has been done in my ownership hopefully it will continue to survive in to the future.
« Reply #134 on: July 08, 2026, 05:32:09 PM »
Well. I for one, given the amount work you’ve obviously put into the little demon. Hope it survives for the future, and you get to enjoy it & the fruits of your labour 🤞
Cheers , Michael
