Author Topic: CB250RSA CUSH DRIVE  (Read 10888 times)
CB250RSA CUSH DRIVE
« on: April 26, 2020, 08:06:30 AM »
I have a new chain and sprocket set to fit to my bike as a job to do during the lockdown.There's some play in the rear sprocket-I don't think it's excessive but would like to try and tackle it.The RSA (as opposed to the D model) has a cush drive which consists of 4 bearings in the sprocket carrier  as opposed to the usual rubber vanes. I've manage to get the bearings but the Haynes manual tells me to go to my friendly local Honda dealer to get these out as a special puller is apparently needed.I have a mate who can do the job for me as he's a bike mechanic but I can't get the bike to him until the restrictions are removed.Has anyone ever tackled this job please?
Dick Scratcher
Re: CB250RSA CUSH DRIVE
« Reply #1 on: April 29, 2020, 10:31:51 AM »
Hi Martin, yes those four 'Metalastic' bushes in the CB250RS rear hub are utter bar-stewards to swap so much so that I never even tried. As they've now been in situ for 40 years there has to be some steel to alloy reaction. I found that as long as the items are still in a recognisable state with the rubber parts intact, a lot of 'slop' between the sprocket and the hub can be successfully reduced by the fitting of a thicker washer under that large circlip. Some years ago my 250 was an MOT failure (by a worthy on the Stourport to Worcester Road who later was told by Ben at Alec Dorrell's "All they're all like that don't worry about it", but it was too late then as he'd already failed it. I scrounged a piece of 2mm (I think) steel plate off a friend and using the original washer as a template I made one, took the bike back later in the day and it passed.  All the best.....Dave.
« Reply #2 on: April 29, 2020, 04:47:38 PM »
Thanks Dave.I think I'll leave well alone -as you say and from my on line enquiries this doesn't look like a job I'd be confident in tackling.One of my previous RS's had a lot more play there and like your's the MOT tester queried it.I'll have a further look when I get the rear sprocket off and see if I can do anything to take up the play under the circlip. My mate will be able to sort it I'm sure.I've probably got a spare washer but whether there's room for 2 under there I'm not sure.
tevie54
« Reply #3 on: May 03, 2020, 09:29:04 AM »
If you can get four new pins and pack the bushes with grease it takes out some of the forward and backward movement and that coupled with a thicker washer does help quite a bit.
« Reply #4 on: May 03, 2020, 10:28:35 AM »
That's a plan...Got quite a few used ones I could try as well.Dave Silver lists these at £7.25 each + VAT + P&P but there's a seller on Ebay selling them with the bushes and nuts as a set of 4 for £18.95 BUT they are for the CG125. I wonder if they will fit the RS?
« Reply #5 on: May 03, 2020, 04:36:58 PM »
Just checked and the CG part numbers aren't the same unfortunately but CSM also have parts in stock.
tevie54
« Reply #6 on: May 03, 2020, 05:36:19 PM »
As a short term fix I've even wrapped the pins in shim steel to take up the slack. Unfortunately the bushes wear into an oval shape so there's always a bit of movement.
« Reply #7 on: May 18, 2020, 09:52:50 PM »
Just had a report from my mate who has now been able to start working on my bike and he tells me the bushes have no wear but the play in the sprocket was caused by an undersize washer being fitted under the circlip.
« Reply #8 on: May 19, 2020, 05:46:38 AM »
Wow, excellent result!  ;D
« Reply #9 on: May 19, 2020, 04:53:10 PM »
Yes and luckily I had the correct sized washer in my cashe of spares.He's also been able to select the best mounting pins from my spares and these steps have totally eliminated any excess play
« Reply #10 on: May 20, 2020, 09:41:55 AM »
It's a proper Aladdin's cave, round at Martin's - the king of spares and very generous with sorting out members in need 👍😁😎
Dick Scratcher
« Reply #11 on: May 20, 2020, 02:04:50 PM »
A friend of mine also had a CB250RS came up with a solution that I 'borrowed' off him and that was to buy from a bearing supplier four Neoprene 'o' rings that were a snug fit over the four drive 'pegs' with thin stainless washers against the Metalistic bushes and then replacing the sprocket carrier back on the hub. It can be a bit of a struggle compressing the carrier adequately to get the large securing circlip into it's groove. I got around it with two strips of metal plus a short length of 8mm threaded rod as a 'puller' to squeeze the 'o' rings just enough.
« Reply #12 on: May 25, 2020, 03:27:22 PM »
Thanks.......Well it's also having its balance chain adjusted-apparently this way way overdue,engine cases and fork legs painted and some other jobs I'm not able/not competent or just too lazy to do.Oh and trying to get rid of the ever present rocker cover oil leak.
BrendanO
  • Procrastinating in Embra
« Reply #13 on: May 25, 2020, 06:57:37 PM »
That's jogged a vague memory of waggly sprockets on zsuperdreams in the 90s, and I think thicker washers were the trick there. I was told that the sprocket eventually wore the wheel out, as it was harder (never found out, my 250N died after 3-4 years of urban commute, outside parking, vandalism, and trips to Shetland, Norway, and Cornwall from Embra).
Never an issue on the 250RSs I had, but only had one RSA (Deluxe). I'm sad to say i blew that one up and to my shame it was my fault. Lnly time I've ever done that.
Xbally, delighted you got a cheap easy fix! Looks like God not on his Harkey...this week.
non-thumpers CX500EC, NTV650P
« Reply #14 on: May 25, 2020, 07:24:12 PM »
Superdream just not the same as the RS-had a couple-Ok but too heavy for a 250-I believe they were designed as 400 originally .
