Author Topic: Wont start when hot...  (Read 1712 times)
boze
« on: April 25, 2007, 04:09:11 PM »
Hey the bikes running sweet as a nut except for this one problem, she starts first kick when cold (no problem there...) but when shes had time to heat up, starting her is like trying to get blood from a stone!!!
i dont get it, is she running rich?
Damo
Re: Wont start when hot...
« Reply #1 on: April 25, 2007, 05:44:48 PM »
Damo
I can smell fuel. Anyone else smell it?
« Reply #2 on: April 25, 2007, 06:25:46 PM »
next time it won't start when hot, take the plug out and check the colour of the end of it.
if its a black/sooty colour then its running rich.
btw, you'll probably burn your fingers taking the plug out. may i suggest a glove ;-)
350bullet.
« Reply #3 on: April 25, 2007, 07:07:53 PM »
Or a plug socket with a rubber insert....
Frog
« Reply #4 on: April 25, 2007, 07:15:41 PM »
I had this problem with a magneto ignition bike (old Triumph) (- I am  not sure it translates) but having chased carburation for ages it turned out to be a weak spark........
Frog
cloggy
« Reply #5 on: April 25, 2007, 07:17:08 PM »
[Takes deep breath] Check if you have a spark first{when it's hot} before you start delving in the carb. Isolate the easy options  first.
GB500nz
« Reply #6 on: April 26, 2007, 09:10:07 AM »
I dunno, but motocrossers have the same problem. Take a look at a motocross race on TV and you'll see riders who have stalled pushing their bikes off the course in disgust after futilly kicking their engines over until they can't do it any more. Maybe turn the petrol off and kick for a while? Or get a GB?
boze
« Reply #7 on: April 26, 2007, 01:57:49 PM »
 Or get a GB?
NEVER!!!!!
hahaha
Damo
boze
« Reply #8 on: April 26, 2007, 01:58:20 PM »
ill check the plug tomorrow, damn night shift is killing me....
Damo
« Last Edit: April 26, 2007, 02:00:11 PM by boze »
peterj
« Reply #9 on: April 28, 2007, 12:20:33 PM »
My SRX used to be a pig to start from hot. New plug and much fine tuning of the pilot air screw sorted that out, or maybe I just developed a better starting technique?
I found that giving up on the decompressor/indicator and just easing over compression slowly on the kicker was the best technique on my SR, but I have no idea how good it's compression was.
TOAD
« Reply #10 on: April 29, 2007, 07:47:03 AM »
Hi Boze,you seem to be having similar problems with your SR500 as I'm having with my SR250.Someone recommended I should try fitting a IRIDIUM plug as these have a stronger spark and can sort out a lot of starting/running problems.
I'm going to get one,it's worth a try.Although they are more expensive than normal plugs (about a tenner I think).
beeman
« Reply #11 on: April 29, 2007, 12:18:57 PM »
I've switched to iridium plugs, seems to run cleaner and on ther dyno was worth about 1bhp( which is  alot when you only started with 31bhp). I've never had any problems starting from hot but then I never had! So can't say it makes a difference.
cloggy
« Reply #12 on: April 30, 2007, 08:55:31 PM »
Just a thought. how exactly do you try and start it when hot?
You mustn't ever use the choke, and if after 3 or 4 good kicks it doesn't start then you wind the throttle fully open and using the decompressor give it ten good kicks to dry the plug. Then you go through the standard procedure again, ie find compression, lift the decompressor and ease it just past top dead centre and then normally with an utterly closed throttle you give it a bloody good kick . Some motors respond better to a tiny bit of throttle but generally jap singles of that vintage shoud be started with no throttle, assuming you've got the idle set about right.
I'm an expert at this I am.
Some years ago when I was a triathlete I went  along to see the local ex SAS fitness instructor for some injury or other.
He had me stand against a full length mirror and on looking me over enquired if I'd had polio as a child.
 No,  just 18 years of kickstarting singles...
« Reply #13 on: April 30, 2007, 09:31:26 PM »
Mmm kinky...
Oh sorry you had the injury already...
boze
« Reply #14 on: May 01, 2007, 02:11:16 PM »
i never ever use the choke, even when shes cold.
i think its kinda sorted now though, ive been footering with the air/fuel mix and seem to have got it right.
peace
Damo
