Author Topic: szr sprag clutch  (Read 607 times)
chippy
szr sprag clutch
« on: April 13, 2007, 12:01:17 PM »
Hi
   I posted on here a couple of weeks ago,it was to identify an srx/bitsa.
   I bought the bike it is a srx frame tzr forks and wheels with a converted szr engine,I spoke to a previous owner that gave me this info as far as he knew it is correct info,the engine is close to 780cc .It started ok a few times but it has a fault on the starter whereby it doesnt turn the engine over it just whines,after a dismal attempt at bumping it(too fat,too slow,too old)it started on the button again,but wouldnt the next time it stopped.
 So this being my first bike with a button start,i am flummoxed. Where do I get new parts?Is this a common occurance with this model? Is this expensive?I am a tyke!
      Any advise would be appreciated  Chippy
Re: szr sprag clutch
« Reply #1 on: April 13, 2007, 01:41:06 PM »
Hello mate,
Sounds interesting!  If its a 780 engine it'll very likely be hi compression.  660cc is standard.  Try using a car battery (just to prove your point, I'm not suggesting fitting a trailer!!), because the standard battery usually struggles (my mz skorpion uses the same motor).
Not sure about this special, but my MZ has a little black solenoid, check this as a start.  Not sure about sprag clutches etc, never had a problem with mine...
And I *can* bump the skorpion, but only on a hill, and probably with a push.
Some photos may be nice!  Where are you?  If your round norff london I may be able to have a look n help you out at some point??
chippy
« Reply #2 on: April 13, 2007, 08:50:06 PM »
Hi
   Thanks for the reply,It is the battery!! A guy I know who has been in the motortrade all his life gave it a once over and said I need a powerful battery and an optimate.
  I have been looking at some batteries called Oddysey,they are glass mat types ,they sound superb but expensive,another option is a varta glass mat,there is a stockist locally,so I am going to see tomorrow.
 I can take some pictures ,but do not know how to post them!
 I have a metisse with a chair on powered by a g80 cooking engine and a 55 16ms ajs and an oif a65.I liked the srx thing so i sold a lightweight matchy i had to make room for it.It certainly goes very well once it hits 3k,but a bit stuttery below.
 If you can give me any tips on posting  pictures,i will take some.
          cheers chippy
« Reply #3 on: April 14, 2007, 06:15:20 AM »
Pictures can be uploaded here
http://www.thumperclub.com/uploadphoto.php
Steve
