Toad listen it is possible to lower every bike so it will fit you ,
dont let the seat high influence your choise of bikes ,
its extremly easy just fit some shorter rear shocks/longer bones and take some material away from the seat and drop the forks a bit in the yokes, get higher clipons /higher handlebars and its done , works on every bike that way
because if you dont do it that way you will always make a compromise ..."i dont like the bike , i dont like the handling , but its the only one that was low enough "
there is a whole industry out there to lower bikes for the vertical challenged
just go out look around and " yeaaaa thats the bike i want to ride"buy it , get a lowering kit for it if its to high and you will be happy , because you didnt make a compromise
otherwise you are basically limited to small 250cc cruisers , not bad bikes actually , but not to everyones taste or?
