Out on a club run today on the 1953 RE J2, and bike starts to run rough, and becomes increasingly difficult to start. With the help of some knowledgeable folks, we tried to reset the points gap, which appeared to be very wide. Discovered that the adjustable part of the points, the threaded bit with a lock nut, wouldn't adjust properly. Turns out this tiny screw had stripped the female thread from the alloy points block. Set off again, and all was good, but soon deteriated back to sh1t, as the points worked loose again. Limped home with a very poorly running machine
Will contact Hitchcock's on Monday, but just wondered had anyone any advice? Could I maybe try drilling and tapping out the points block?
Oh, and the alloy throttle body disintegrated into tiny pieces as well
