Author Topic: Electronic Tacho  (Read 517 times)
silver
Electronic Tacho
« on: July 03, 2017, 09:43:42 AM »
Hi, Does anyone know where I can get a Tacho with a budget of about £50. all the ones on Ebay seem to be for multi cyclinder engines. I found one for a twin, could I use that?
This is for the supermono trackbike project. They usually insist on one for the noise test. That's why I don't want to spend a fortune.
I thought I might be able to get one off a modernish 125 road bike but they are mostly cable driven.
Any help would be appreciated .
Dave
1988 XBR500 (Near GB Spec)
2018 BMW G310GS
2010 Street triple R
Yamaha SZR 660 (pending)
Re: Electronic Tacho
« Reply #1 on: July 03, 2017, 10:11:30 AM »
These work well Dave :-
http://www.ebay.co.uk/itm/Digital-Tach-Hour-Meter-Tachometer-Gauge-For-2-Stroke-4-stroke-Gas-Engines-/192030701646?epid=505922864&hash=item2cb5ebf84e:g:wLgAAMXQWzNSeGYa
just wrap the cable round a spark plug lead, configure your engine type and away you go. I've used them several times in the past. If you're handy with a soldering iron, you can even prise the back off, take the internal battery out and solder some leads on so you can run it from an external battery pack ie, 2 AA baterries in a battery holder.
silver
« Reply #2 on: July 03, 2017, 10:43:10 AM »
Brilliant, I think £4.34 should fit in the budget. I'll give it a go. I'm not one for over revving a single so it should be fine for getting the noise test done.
2018 BMW G310GS
