Hi Mackenzie,
I've recently started to repaint my hubby's Honda Vigor tank. It was in OK condition with some areas needing sanding back to the metal, decals removed and those areas 'flattened' with 400 grade wet & dry. The majority of the tank was original paint.
I made sure the whole tank was keyed, by sanding the whole tank. (Not back to metal) I cleaned the surface with panel wipe, sprayed the bare metal with etch primer, then stared with a fine coat of high build primer. Better adhesion for any further coats is achieved this way.
You can apply another fine coat of high build. Any areas that need further filling should get filled and sanded if necessary, then 1 decent coat of high build.
Sand with a finer paper, say 600, then apply your top coats of colour. I'd recommend 4. Any decals go on before lacquer. Lacquer approx 4-5 coats.
Hope this helps
Ali
PS. You should b able to post photos (restricted in size) by hitting the blue 'Attachments and other options' link at the bottom right of these text boxes in messages.
