Author Topic: xbr500  (Read 461 times)
guest1826
xbr500
« on: June 02, 2014, 05:45:40 PM »
I want to fit an xl 600 barrel and piston to my xbr 500, would I need to modify the head and with ref to carbs, wld I need to put a 650 carb on??? cheers
guest1822
Re: xbr500
« Reply #1 on: June 02, 2014, 08:01:03 PM »
Will it fit without modding the frame? The XL lump is a wee bit taller.
Re: xbr500
« Reply #2 on: June 02, 2014, 08:37:27 PM »
Yes you can fit a 600 barrel but you need the right one. I believe you can also use the XBR head ** don't panic if you find a crack from the plug hole to one of the valve seats- most XBR's have it and it doesn't seem to have any effect.
If you put 'XL600 barrel' in the site search it will bring up a number of threads on the subject.
